Results 1 to 2 of 2
    DeLuXe's Avatar
    Mar 2019
    Default Bosch ABS 8.0 - Software or configuration
    Hi!
    How are you all doing?
    I got an issue with Bosch 8.0 ABS that is currently on a RV.
    The old abs unit is water damaged and the new used one is showing configuration fault since it says coming from manual transmission and the rv is automatic one.
    My biggest question if its somehow possible to change the config on these Bosch 8.0.
    I'm happy to pay for the help. The donor ABS is mounted on the RV. I have communication with one machine but not another so i am little confused.
    Thanks all for help and guidance!
    Best regards,
    DeLuXe
    Sharing is carying. Please press Thanks + Rep Button if my post is helpful
    DeLuXe's Avatar
    Mar 2019
    This is solved by repair the old unit.
