Results 1 to 12 of 12
    Baddog84's Avatar
    Sep 2012
    Germany
    Default Audi TT 1.8T ori
    need full read from Audi TT 1.8T
    8N0906018CA
    0261208086
    375111
    mpc and flash
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  2. The Following User Says Thank You to Baddog84 For This Useful Post:
    DiggeA (20th May, 2020)
  3. #2
    RBTuning's Avatar
    Oct 2019
    amsterdam
    Default original file
    Ii also have stage 1 if you are interested.
    you can add me on skype for future maps
  4. The Following 2 Users Say Thank You to RBTuning For This Useful Post:
    alyvo (18th April, 2020), Baddog84 (17th November, 2019)
  5. #3
    Baddog84's Avatar
    Sep 2012
    Germany
    hi,
    thanks but also need mcp from the car full ktag read
    Quote Originally Posted by RBTuning View Post
    Fileservice
    no thanks no pass
  6. The Following User Says Thank You to Baddog84 For This Useful Post:
  7. #4
    Baddog84's Avatar
    Sep 2012
    Germany
    nobody has anything?
    Fileservice
    no thanks no pass
  8. The Following User Says Thank You to Baddog84 For This Useful Post:
  9. #5
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    Quote Originally Posted by Baddog84 View Post
    8N0906018CA
    0261208086
    375111
    mpc and flash
    your flash, what for mpc?
    Don't forget hit thank button if i helped.
  10. The Following User Says Thank You to vitaliyl For This Useful Post:
  11. #6
    Baddog84's Avatar
    Sep 2012
    Germany
    need ktag full read with mcp for clone and tun the car
    Fileservice
    no thanks no pass
  12. The Following User Says Thank You to Baddog84 For This Useful Post:
  13. #7
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    i don't see the need to have ktag full
    you can only make a clone from a flash
  14. #8
    Baddog84's Avatar
    Sep 2012
    Germany
    already tried not possible
    also need mcp for some changes
    is bigger turbo Project
    Fileservice
    no thanks no pass
  15. The Following User Says Thank You to Baddog84 For This Useful Post:
  16. #9
    carmageddon's Avatar
    Apr 2010
    Italy
    no need mpc to make correct changes when mounting big turbo, big injectors, pistons, rods or any other modification to your engine
  17. #10
    vitaliyl's Avatar
    Aug 2018
    Ukraine
    use any mpc from the motor BAM 225ps 8N0906018CB or other
  18. #11
    Mar 2025
    Does anybody have the eeprom for 018ca ?
  19. #12
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Quote Originally Posted by olivia88 View Post
    Don't be a grave digger.
    Chiptuning File Service 24/7
    Thanks+Rep If I helped you!
