Results 1 to 4 of 4
Hybrid View
    Sep 2011
    Default Best OPCOM adaptetr and software help
    I have a 63 plate 2.0 astra elite diesel. I want to buy an Opcom adapter but im so confused with all the different options. Where to buy an original working opcom and what software? which clones and which firmware do i need to be on/ do i need cracked version of software HELLLLP!!! Im so confused what will work best with my car?
    Mar 2025
    Europe
    Quote Originally Posted by madhatter View Post
    I bought Chinese clone Opcom 2021 with firmware 1.95 and i was not satisfied with the options who were applicable, i could read and remove DTC and nothing else, in measuring block tabs nothing showing also i cant program etc. If you want beter OPCOM try to find from someone who has better firmware versions,you can find on forums for sure someone who is selling it, or depends on your needs. The OP com is showing cars up to 2021. My car is Astra J 81kw 1.7cdti
    Apr 2025
    Belgium
    If in measuring blocks nothing is showing (all ---) that's most likely in that version of the software your car's live data is not yet supported. You should install a newer version.
    Mar 2025
    I can install Op-Com for you remotely if required and I have a spare interface I can supply 👍
