Results 1 to 2 of 2
    May 2022
    Default Need help for EDC17C64 GOLF 7 1.6 MANUAL TRANS
    Golf 7 1.6 ECU EDC17C64 is completely dead and i bought a used and good same ECU with same ref but automatic gearbox.
    CAR INFO:
    Golf 7 1.6 TDI 105 CV / 77 KW Diesel 2012 - 2025 CLHA
    VIN: WVWZZZAUZFW043950
    ORIGINAL ECU INFO: https://ibb.co/gb4dw49j
    NEW USED ECU INFO: https://ibb.co/3YkvDBb6
    NEW USED ECU FULL READ (MICRO TC1797 AND EEPROM) is attached. THIS USED ECU IMMO DATA IS ALREADY MATCHED, CAR START BUT CODING NOT CORRECT.
    I dont have original ecu map and eeprom, i need to code this automatic trans ecu to my car, VCDS doesn't accept coding, its rejected.
    Please anyone can help me for this?
    I need correct files for manual transmission engine, with checksum ok.
    NEW ECU LONG CODING:
    01250012032405092000
    I THINK IT SHOULD BE:
    01110012032405092000
    Thank you.
    Edber's Avatar
    Nov 2018
    BiH
    Your car start...which is mean that immo is OK. Did you flash your new ecu with vw original (manual gearbox) flash file ( .frf/ .sgo file )?
    After that try to make new codding with VCDS.....Many members gave me advice that I don't use new ecu with different type of gearbox than original ecu.
    If I help you, just press Thanks and Reputation please.
