Results 1 to 4 of 4
    Default VTX MasterTech Instrumentation Port Cable
    Hi Alls,
    Does anyone have the pin out of this cable?
    It's a RJ45 10-pin cable connected between Vetronix Mastertech MTS 3100 scanner and vehicle break out box(VBOB) or NVH vibration analyzer.
    I've tried RS232(Scanner > PC) 10-pin flat cable but not working!
    This cable is discontinued from Toyota/SPX tool supplier(part number: 02001720-01).
    Please upload cable pin out if you have one!
    Thanks in advance.
    Top Poster rrob311's Avatar
    I have the pinout of the actual port that goes into the scantool. I have the Kia version of the scanner. It shouldn't be as impossible if you have 1/2 of the info. If you want I can grab the manual and scan a picture for you. Just let me know. I know the outer 2 pins are not used off the top of my head.
    Thanks for replying!
    I found my old Tech 1a cable & used it instead.
    Junior Member cbeerman's Avatar
    New Jersey
    Can you post the pin out of the I/P port?
