Results 1 to 2 of 2
    Mar 2019
    Default Help needed EDC16C39 Alfa GT Launch Control
    Hey guys, been working on my Alfa GT 1.9 JTDm (Q2 diff, fmic, ducati corse / q2 turbo) and I was wondering how could I achieve launch control in this ECU. I know the classic VAG trick with drivers wish doesnt work on these ECUs, came across EngPrt_qOvhtPrvVRng_MAP - map for vehicle speed dependent quantity limitation with Y-axis "minimum prevention factor calculated from temperature curves". It looks like it could be done through that, but to be honest I dont really get what the Y-axis is, and how could I modify the map to achieve launch control through it. If anyone has an idea, or possibly a better way to do this, let me know. Any help is appreciated. Attaching .ori file so I can learn from it, if someone decides to do it for me.
    Jul 2024
    MKD
    Default LC
    Here pass in pm.. If i help press rep and thx
  3. The Following User Says Thank You to damjantuzeski For This Useful Post:
    Adamkovac2000 (20th April, 2025)
