Results 1 to 2 of 2
    Mar 2009
    Question Diagbox 5.29 Data Access Problem
    I have an old Lexia interface, revision B, so I have to use Diagbox 5.29 and no higher.
    I’ve set up Oracle VirtualBox on a Microsoft Surface Pro i7 tablet running Windows 10 and I’ve installed Windows XP SP3 on it.
    After carrying out the hide87.com fix for a Wincad general protection fault error, I’m still having no luck getting Diagbox to work. I keep getting “Data Access Problem”.
    What does this error actually mean, and what might be the cause, does anyone know?
    Aug 2022
    Beirut,Lebanon
    Hey bro,
    Check for interface and LAN drivers or reinstall them, maybe the VM is not passing the Lexia interface to the Windows Guest OS.
    Always run as administrator.
    Also check this forums i think switching to version 7x was stable and worked:https://frenchcarforum.co.uk/forum/v...ic.php?t=65875, https://www.peugeotforums.com/thread...-v7-60.244617/
    Thank you in Advance.
