Does anyone know if the Dreambox 7025 takes the Al Jazeera Sports Card in Irdeto without a cam. The older ART card was Viaccess and just inserted into card slot. Thanks.
I will check this today and let you know
I have checked this on DM7000 original (Gemini 470) and DM800HD clone (Gemini 460) and managed to get Al Jazeera Irdeto card working.
I have CCcam 2.1.4 installed on both boxes. I managed to get the card working using the CCcam with some minor modification.
If you have CCcam configured for sharing, BACKUP your var/etc/CCcam.cfg file
- Install CCcam_Config addon from Addons (Blue button -> Addons -> Download Gemini Server -> Cam_Configs)
- FTP to your box and open var/etc/CCcam.cfg file
- Search for the below line. Remove the # at the begining of the line
CAMDATA: /dev/sci0 11 22 33 44 55 66 77 88 99 aa bb cc dd ee ff
- Search for the below line. Remove the # at the begining of the line. And Replace ttyUSB0 with sci0 (or sci1 depending on the card slot u r using)
TRY ALL CHIDS : /dev/ttyUSB0
The line should be TRY ALL CHIDS : /dev/sci0 (or sci1 )
- Save the file and upload it back to the box in var/etc/
- Plug the card inside the box (chip face down)
- Restart the CCcam (Blue button -> Green Button)
This should be enough to make the card works.
If you are using CCcam configured for sharing, you can safely open var/etc/CCcam.cfg file and add the config line (C: server port user pass) at the begining it. Save it, and upload it back into the box.
If you don't want to mess with your CCcam, you can simply install Scam 3.59 (Blue button -> Addons -> Download Gemini Server -> Cams). Use the Scam and restart it after you plug the card in the box.
nafnes (14th November, 2013)
The above post if you want to have an idea about the configuration. If you don't want that and you just want your card to work, download the uploaded file, unrar and upload it into your box var/etc
Note: if you have CCcam sharing configured, just add the sharing line at the begining of the file, save and upload.
Thanks for that, seems a bit complicated but will give it a go when card arrives. Should be Wed/ Thur. Did not want to order till i found out if it worked.
In appreciation of the extent he went to help you i find that it would be a good idea to atleast use the thanks If not rep buttons for his posts.
Read the Rules here; they apply to Everyone.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 Motor
Just joined and this was one of the questions that i wanted answered. So I will say thanks iKay for your work on this.
Aljazeera is changing Jsc sport cards 319xxxxxx series with new 322xxxxxx series.... (from viaccess 3 to viaccess 4.0), So a few changes over the coming weeks.
Great Info. Thanks!
thank you so much
