I have a 2023 Mercedes-Benz Sprinter W907 from the US. I need to recode the rear lights to work like in the EU (without turn signals on the brake lights), the rear lights are prepared for this (I cut the plastic and put a yellow bulb into the turn signal light + added a cable with a pin to the lamp socket and made new cables from SAM for a separate turn signal) - as I checked in the ECE Sprinter specification, I only need help with what I need to recode in SAM V2 (MB no. 9079017702 SAM V2) to make the rear lights work like in a European Sprinter. Because now I have: parking light, brake light and turn signal on one wire (US specification). I need European specification, parking and brake lights on one wire, and turn signal separately on the other wire. I checked the wiring in ECE and did what I wanted, but I don't know what coding I need to change to make everything work properly. If anyone has knowledge PLEASE help, I would be very grateful.
Best regards
Jarosław "j4ru"
