Hi again,
so I wanted to read out another Opel E98 ECU (2016 Astra K) but I cant connect using IO Terminal.
I cant create a key because the SEED has only 4 characters -> B126. My key generator says the Seed is invalid.
I tried creating keys by entering B126000000, 000000B126 and some more variants (e.g less zeros), but keys that were generated all seem to be incorrect since I cannot connect to the ECU.
Is this 4 character Seed normal?
Can anyone help me retrieving the key?
here some ECU info:
System Supplier ID : CONTI0100
System Name or Engine Type : ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
End Model Part number : 55494027
Supplier ECU hardware number : 55485508
Boot software part number : 55595656
Boot software. Alpha Code : AA
Software module 1 ident. : 55506709
Software module 1 ident. Alpha Code : AA
Software module 2 ident. : 55509982
Software module 2 ident. Alpha Code : AE
Software module 3 ident. : 55509986
Software module 3 ident. Alpha Code : AE
Software module 4 ident. : 55509979
Software module 4 ident. Alpha Code : AE
Software module 5 ident. : 55509989
Software module 5 ident. Alpha Code : AE
Software module 6 ident. : 55509994
Software module 6 ident. Alpha Code : AG
Software module 9 ident. : 55584868
Software module 9 ident. Alpha Code : CA
Software module 10 ident. : 55495500
Software module 10 ident. Alpha Code : AB
Hardware Key Number : O301009009
Programming Date : 20231130
Odometer : 165909
SEED : B126
(programming date is 2023 even though model year is 2016 because the car got a SW update)
JROM
