Results 1 to 9 of 9
    Dec 2008
    Default 2007 Honda Jazz key not programming.
    Hi all,
    Struggling with the above, all keys lost situation.
    Got key from 3D, it's 8E transponder key.
    Tried Autel, AVDI, Lonsdor and OBDSTAR, no luck programming the key in.
    Does this have to be done manually by reading the immobiliser/antenna ring unit eeprom and then generating the key?
    Thanks in advance for the help.
    Dec 2009
    UK
    Are you sure its not a late registered one? think the early ones are ID48. Have you tried sniffing the antenna ring?
  3. The Following User Says Thank You to the_big_d For This Useful Post:
    p1et (28th April, 2025)
    topclef's Avatar
    Mar 2010
    Honda Jazz 2003 to 2006 use Megamos 48
    Honda Jazz 2006+ use Transponder ID46
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
    Mar 2018
    UK
    Quote Originally Posted by topclef View Post
    Wrong id46 is 2009 onward
  6. #5
    Dec 2008
    HONDA JAZZ 2001-2006
    Transponder Megamos Crypto 48 / ID48 / JMA TP08 OR Megamos 13 / ID13 / JMA: TP05.
    HONDA JAZZ 2006-2008
    Transponder Sokymat Crypto 8E / ID8E Honda. OEM Kev: 35111-SAH-305 and others.
    HONDA JAZZ 2009-2014
    Transponder Philips Crypto ID46 / Hitag-2 / PCF7941A / PCF7961A/ PCF7936. OEM Key: 35113-SWA-E00, 35113-TVO-E00 and others.
    I'll try sniffing the antenna ring to see what transponder to use
  7. #6
    Dec 2012
    EU
    Last one i done was with autel im608
    Akl obd
    Just cant mind what transponder.
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  8. #7
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    8E by OBD should be not a problem.
  9. #8
    kemaster's Avatar
    Mar 2010
    BG
    I always use old X100+ for these. Never managed to make it with OBDSTAR Tablet. But this for key adding. Never have tried all key lost on this model and year
  10. #9
    Dec 2008
    Sniffing the antenna ring gave nothing.
    Diagnostic shows no communication between key and immobiliser unit, suspect antenna ring module around ignition is faulty
