Hello I have problem the ecu is EDC16U34 from Superb mk2 2.0tdi pd bmp engine code i think 103kw, i switched off dpf by swtich in soft and egr by hysteresis 2 and 5 map to 0 value. I reset dpf values with vcds via adaptation. but the car have raised iddle at aroun 1000rpm and coming bad smell white smoke from exhaust, all sensors are disconnected no dtc in memory just high idle speed and bad smell white smoke i atach ori and mod file.
