for me i use XPROG
you must lift pin 1,12 and 15
and for the frequency mercedes key have 2 : 2MHZ and 4MHZ chek the quartz ....
for me i use XPROG
@Nabil1987, its not mercedes key but Avensis immo coil
@SOGARO
it's the same , just chek you quartz i think it's 4MHZ
hello mr sogaro
from where did you bought your ak400 which i think it working very good
China from CNAUTOKEY TECHNOLOGY CO., LTD.
Hi sogaro
Use Xprog-M it will work 100%
just lift PIN1 (VppR) and connect Xprog on MCU pin not board ( guess this is logical for you).
check Frequency of crystal and set in Xprog option "environment" that should be : 2000000Hz or 4000000 Hz.
I have read lots of toyota immo and MB keys with HC05E6 SMD 28 with Xprog-M.
I can help you with key calculation too, if you need for toyota.
Sure my friend i will need the key logic but can you post a real life pix of the connections as am scared stiff of spoiling the chip due to wrong connections.
you won't ...just dont forget to lift pin1 and follow connection diagram of Xprog-m
UPA CONECTION
LIFT UP PINS 1, 11, 12, 15 AND 16 OF MCU.
UPA.............MCU
1...................1
2...................11
3...................12
5...................28-Vss
6...................16
7....................2
8....................15
9...................27-Vdd
Choice 2 KHz oscillator it is important.
WBR
bokilee (21st November, 2014), Diag175elec (11th December, 2013), killian2008 (30th August, 2018)
i READ THE HC05E6 AND HERE IS THE DUMP, I READ THE KEY DATA AND ITS ALSO IN THE DUMP BUT CAR WONT START WITH IT, I CANNOT PUT THE KEY DATA IN THE DUMP SINCE ITS THERE ALREADY, DO I VIRGIN DUMP TO USE KEY OR WHAT SOLUTION IS AVAILABLE AS CAR STARTS AND DIES
Recognizing transponder...
Transponder recognized as Texas fixed
ID 4C - JMA TP02/TP07
TIRIS Data: 7E 27 AD 5E 02 00 00 00 00 64 8E 7E
please try these dumps.
If still no start then check ECU eeprom ,maybe sync bytes are not ok. They should be : 32 39
in avensis you must use 4D chip
WBR
