Results 1 to 10 of 10
    Gammoudi's Avatar
    Dec 2017
    ECUS
    Default FIAT DUCATO DPF EGR
    hi everyone i need dpf egr off for fiat ducatto 2020 wirth ecu marelli 9DF
    dtc is P040A
    flash dump attached
    thanks in advance
    Nov 2018
    BiH
    Try this egr dpr off....chk ok
    Pass in pm..
    If I help you, just press Thanks and Reputation please.
  3. The Following User Says Thank You to Edber For This Useful Post:
    Gammoudi (Yesterday)
    Oct 2023
    Quote Originally Posted by Gammoudi View Post
    dtc is P040A
    flash dump attached
    thanks in advance
    If your vehicle has an adblue system and you want to close the dpf, adblue must also be closed.
    and your vehicle has adblue system
    Oct 2023
    Quote Originally Posted by Edber View Post
    Pass in pm..
    This solution will not work without canceling adblue
    Gammoudi's Avatar
    Dec 2017
    ECUS
    Adblue is already off ..
    Gammoudi's Avatar
    Dec 2017
    ECUS
    Pass in pm..
    this solution already tested not work
    Nov 2018
    BiH
    Did you cleat DTC error before reading file from ECU? 9DF ecu's is very problematic with dpf egr off....it is hard to find good solution for this car...
    Oct 2023
    I have a solution that really works and has been tested many times before. If you wish, I can help you.
  10. #9
    Gammoudi's Avatar
    Dec 2017
    ECUS
    Quote Originally Posted by ecustand View Post
    Can you help ...
  11. #10
    Gammoudi's Avatar
    Dec 2017
    ECUS
    Yes i did clear dtcs and the same
