Results 1 to 11 of 11
    Dec 2019
    Germany
    Default Opel delco E98 IO Prog wrong file size
    I have an insignia with delco E98 ecu.
    Someone Flash the ecu for me with stage 1,egr and adblue out.
    But now i have a adblue dtc, it says i have 900km left bevor engine doesnt Start.
    I bought a io prog and want to roll back to original Software.
    When i read Flash an save it the file size is 4.096kb
    My original file that was created from the tuner is 4.128kb
    Ioterminal says file size must be 0x400000
    What can i do? I read this via obd2.
    Thanks in advance.
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Different programmers read different sizes
    It is important that the original file is readable in full, i.e. flash and virtual eeprom
    If this is your first programmer and you are new to programming, be careful.
    PLEASE PRESS THE " THANKS " BUTTON
  3. The Following User Says Thank You to gwiazdamb For This Useful Post:
    Burnsi (10th May, 2025)
    Dec 2019
    Germany
    I Made a few ecu with kess clone.
    But this is a E98, thats why i bought io prog for Opel.
    Can the file be modified for my io prog?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    If you have the original full file then YES
  6. The Following User Says Thank You to gwiazdamb For This Useful Post:
  7. #5
    Dec 2019
    Germany
    This is what i have.
    Can you take a Look?
  8. #6
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    The file looks original
    But it is not a full reading, there is a missing eeprom
    With this reading you don't have a backup copy
    In case of a write error you may lose your ecu
    You have Adblue disabled and you have an Adblue error, this is a bad Adblue mod
    I suggest going back to the tuner, it won't fix it
    If you still want to go back to the original, give the Ioterminal reading
  9. The Following User Says Thank You to gwiazdamb For This Useful Post:
  10. #7
    Dec 2019
    Germany
    this is my reading
  11. #8
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Please...................
  12. The Following User Says Thank You to gwiazdamb For This Useful Post:
    Burnsi (11th May, 2025)
  13. #9
    Dec 2019
    Germany
    Wow, Thanks you.
    This is the original Software for my ecu now?
    rename to flash.bin and flash it?
  14. #10
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Be very careful with e98....
    First at all read and save password... if you don't have shadow password, then you will be in trouble if your ecu is unreadable by odb or bench.....
    Η κότα έκανε το αυγό ή το αυγό την κοτα;
  15. #11
    Dec 2019
    Germany
    Quote Originally Posted by Panathaole View Post
    OK, i have both files saved.
    Shadow Pass, i write it down.
    Do i have to do something else?
