Results 1 to 13 of 13
Hybrid View
    Jan 2020
    UK
    Default Honda civic 2006. Learning remote problem
    Hi guys.
    I have Honda Civic 2006. This was Akl situation. I managed to program transponder. Car starts. However I am having problem to enter remote learning mode. I use xhorse remote. I tried switching ignition fast and press lock button then slow nothing.
    Do I need right remote to enter this mode or doesn't matter and remote will be accepted or refused. I am not sure it has something to do with engine start button. There is a mechanical key and separate engine start button as per pic.
    I hope you can enlighten me.
    Dec 2010
    Nottingham
    The ideal is to use oem key or good aftermarket key and remote codes with chip , it would also help you if you used the correct remote procedure to manually code remote though your timing is crucial
    1) make sure all doors are unlocked and turn ignition on
    2) press lock or unlock button on the remote once
    3) turn ignition to lock then back on again
    4) press lock or unlock button once
    5) turn ignition to lock then on again
    6) press the lock or unlock button once
    7) turn ignition to lock then back on again
    8) press the unlock or lock button on the remote once at this point if you have done this correctly the locks will cycle
    9) press the lock button on the remote locks should cycle again
    10) turn ignition off and test your remote
    of course if generating a remote you need to generate the correct remote first or have the correct remote key for the job.
  3. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    fuzz1 (13th May, 2025), Plopek (13th May, 2025), wuza (14th May, 2025)
    UK
    Honda Civic 2006 can system ID46, Remote programmed automatically same time as immobiliser, no manual procedure for this model.
    Think you have the wrong key
    Mar 2018
    UK
    Quote Originally Posted by yusef View Post
    Wrong
    This car also have manual procedure but you must know how to do it
    Dec 2010
    Nottingham
    yes if you use correct key with pcf 7961 chip the remote does indeed code in with the transponder , but with some aftermarket and some generated keys this isnt the case and the manual procedure can often sort this out. having the correct key is a big part of the job.
    so sadly you are incorrect , there is indeed a manual procedure for this year of vehicle , however if the right key is used its never required.
    Nov 2013
    Not sure about European/Japan etc. version, but in NA Civic 2006 and up - remote programmed with chip, period. There's no way around it. Manual procedure don't exist, and no tool can program remote separately.
    Edit: Apparently, I might be wrong (see post below). I will try next time to confirm.
    Mar 2018
    UK
    Quote Originally Posted by ranchero View Post
    its a manuale procedure but the devils in the details
    You can't enter in programming mode if the first key that was programmed is chip on board 7961
    So you need to clear all keys and first program separate 7936 chip and after that the car will enter in programming mode with the manual procedure
  9. The Following 2 Users Say Thank You to Manta1600 For This Useful Post:
    .: JaCkPoT :. (19th May, 2025), ranchero (14th May, 2025)
  10. #8
    Nov 2013
    Quote Originally Posted by Manta1600 View Post
    That's interesting. Manual procedure - same as other Hondas? I will try it next time.
  11. #9
    Mar 2018
    UK
    Yes the same procedure
  12. The Following User Says Thank You to Manta1600 For This Useful Post:
    ranchero (15th May, 2025)
  13. #10
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Interesting. I had 2007 in the past and I couldn't get into remote programming mode.
    Since then I have used better keys and always remote is done automatically but next time I have the chance, I will try clear the keys and try this just so I know. Thanks for the info
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
  14. #11
    Dec 2010
    Nottingham
    But at the end of the day , if the correct oem or good quality aftermarket key is used then the manual procedure is not necessary as remote will code in with the transponder, and adequate aftermarket keys are very cheap .
  15. #12
    Mar 2018
    UK
    Quote Originally Posted by rapidlocksmiths View Post
    Yes its worth only if the customer especially want Honda flip key
  16. #13
    richard27's Avatar
    Aug 2011
    You need to open the door with the key and the central locking must be active.
    frequency 315 433 ?
    I think the steering wheel is on the right side and it should be 315
    ​information sharing
