Astra H 1.7 dti 2005
TEMIC 13 188 857
9S12DG128E
Tryed with op-com but will not do it
seem,s to have to many fault,s so must do it the hard way
Can anyone help to remove crashdata Please
Thanks kev
TEMIC 13 188 857
9S12DG128E
Thanks kev
had this before, had to replace both tensioners first, if you look on the opcom forum tells you how to do it, or pay ?45 for crasheraser off ebay user beat-the-garage
Ahhh i see thanks for that, i did try to clear crash with Tachosoft and less codes come back here,s what i ended up with,
B1000 - Replace Electronic Control Unit (ECU)
(39) - Present
B0084 - Invalid Data From Right EFS (Electronical Front Impact Sensor)
(71) - Present
B1000 - Electronic Control Unit Not Reusable
(56) - Present
B001B - Passenger Lap Pretensioner Circuit Open
(04) - Present
B001A - Driver Lap Pretensioner Circuit Open
(04) - Present
U2050 - Invalid Data from SOD (Seat Occupied Detection)
(73) - Present
U2050 - SOD Circuit Low Voltage (Seat Occupied Detection)
(02) - Present
Thanks kev
dont wanna hijack the thread mate but had a 59 plate astra h yesterday, apparantly crash data has been cleared but it had loads of dtcs any one got the PROPER procedure to do it using OP-COM
these wer th codes i got
OP-COM - CAN Communication Window> 2009|Astra-H|Body|SDM (Airbag)
Read Info...
Identifier: 0x0204
VIN: W0L0AHL*********
System name: MRSZ-Temic
Part Number:13288174
Software version number: A3300RG3 V 3.4.0
Hardware key number: ??????????
Variant programming : 0x41532020202054525356394815415045
Alpha code: CA
Manufacturing date: 20090815
Total number of fault codes: 16
(56) - Present
B0051 - Airbag Deployed
(00) - Present
B0053 - Deployment Commanded With Troublecodes in Squib Circuits Present
(00) - Present
B1325 - System Voltage Low Voltage
(03) - Not present
B0016 - Driver Curtain Airbag Squib Circuit Low Resistance
(0E) - Not present
B0019 - Passenger Airbag Squib Circuit (Stage1) Open
(04) - Not present
B0021 - Passenger Side Airbag Squib Circuit Low Resistance
(0E) - Not present
B0012 - Driver Airbag Squib Circuit (Stage1) Open
(04) - Not present
B0023 - Passenger Curtain Airbag Squib Circuit Low Resistance
(0E) - Not present
B0014 - Driver Side Airbag Squib Circuit Low Resistance
(0E) - Not present
U2116 - CAN-Bus No Communication with IPC (Instrument)
(00) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(00) - Not present
U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
(00) - Not present
B1001 - Left Hand Drive/Right Hand Drive Configuration Error
(3A) - Not present
B0019 - Passenger Airbag Squib Circuit (Stage1) Low Resistance
(0E) - Not present
B1000 - Trouble Code Memory Full
(4C) - Intermittent
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
iv already tried that, no luck, has any1 actually tried it and it worked????
wen i start activation, is it supposed 2 give me a message?
these worry me abit
(56) - Present
(00) - Present
also im abit confused, can any1 hee tell me wat parts i need 2 activate by looking at the dtcs???
thanx
i dont to make this sound as dont know what you am doing but i helped a mate repair a astra h few years ago on a 55 plate we had a simlar problem and we got fed up of changing parts make you have changed everything thats needs changing also i was told by vauxhall but the airbag control module is only good for two deployments after that it scrap it might be worth checking just in case its been deployed before.
There are some SDM units that crash data cannot be erazed with OPCOM or TECH 2 clear deployment record function. Last week i had an YQ ident unit. With OPCOM i had the same problem with you. After activation B1000 and B0051 cannot be cleared, so i tried with tech 2. Tech 2 showed crash data cannot be erazed - no more valid usage period. So the only option is via onboard programmer.
I need pass for this dump, or better - if some of you have dump for Astra H MY 2008
