Results 1 to 14 of 14
    kevfield's Avatar
    Aug 2009
    uk
    Default Astra H crash data
    Astra H 1.7 dti 2005
    TEMIC 13 188 857
    9S12DG128E
    Tryed with op-com but will not do it
    seem,s to have to many fault,s so must do it the hard way
    Can anyone help to remove crashdata Please
    Thanks kev
    Meat-Head's Avatar
    had this before, had to replace both tensioners first, if you look on the opcom forum tells you how to do it, or pay ?45 for crasheraser off ebay user beat-the-garage
    kevfield's Avatar
    Aug 2009
    uk
    Ahhh i see thanks for that, i did try to clear crash with Tachosoft and less codes come back here,s what i ended up with,
    B1000 - Replace Electronic Control Unit (ECU)
    (39) - Present
    B0084 - Invalid Data From Right EFS (Electronical Front Impact Sensor)
    (71) - Present
    B1000 - Electronic Control Unit Not Reusable
    (56) - Present
    B001B - Passenger Lap Pretensioner Circuit Open
    (04) - Present
    B001A - Driver Lap Pretensioner Circuit Open
    (04) - Present
    U2050 - Invalid Data from SOD (Seat Occupied Detection)
    (73) - Present
    U2050 - SOD Circuit Low Voltage (Seat Occupied Detection)
    (02) - Present
    Thanks kev
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by kevfield View Post
    TEMIC 13 188 857
    9S12DG128E
    Thanks kev
    Hi.
    Try...your dump cleared 100%.
    Password is in your PM.
    Best regards.
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    dont wanna hijack the thread mate but had a 59 plate astra h yesterday, apparantly crash data has been cleared but it had loads of dtcs any one got the PROPER procedure to do it using OP-COM
    these wer th codes i got
    OP-COM - CAN Communication Window> 2009|Astra-H|Body|SDM (Airbag)
    Read Info...
    Identifier: 0x0204
    VIN: W0L0AHL*********
    System name: MRSZ-Temic
    Part Number:13288174
    Software version number: A3300RG3 V 3.4.0
    Hardware key number: ??????????
    Variant programming : 0x41532020202054525356394815415045
    Alpha code: CA
    Manufacturing date: 20090815
    Total number of fault codes: 16
    (56) - Present
    B0051 - Airbag Deployed
    (00) - Present
    B0053 - Deployment Commanded With Troublecodes in Squib Circuits Present
    (00) - Present
    B1325 - System Voltage Low Voltage
    (03) - Not present
    B0016 - Driver Curtain Airbag Squib Circuit Low Resistance
    (0E) - Not present
    B0019 - Passenger Airbag Squib Circuit (Stage1) Open
    (04) - Not present
    B0021 - Passenger Side Airbag Squib Circuit Low Resistance
    (0E) - Not present
    B0012 - Driver Airbag Squib Circuit (Stage1) Open
    (04) - Not present
    B0023 - Passenger Curtain Airbag Squib Circuit Low Resistance
    (0E) - Not present
    B0014 - Driver Side Airbag Squib Circuit Low Resistance
    (0E) - Not present
    U2116 - CAN-Bus No Communication with IPC (Instrument)
    (00) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    U2141 - CAN-Bus No Communication with REC (Rear Electrical Centre)
    (00) - Not present
    B1001 - Left Hand Drive/Right Hand Drive Configuration Error
    (3A) - Not present
    B0019 - Passenger Airbag Squib Circuit (Stage1) Low Resistance
    (0E) - Not present
    B1000 - Trouble Code Memory Full
    (4C) - Intermittent
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Meat-Head's Avatar
    Quote Originally Posted by z786 View Post
    donny one got the PROPER procedure to do it using OP-COM
    t
    1) http://www.digital-kaos.co.uk/forums...53/#post549416
    2) if too lazy http://opcomforum.yolasite.com/resou...ent%20Data.pdf
    z786's Avatar
    Aug 2009
    iv already tried that, no luck, has any1 actually tried it and it worked????
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    Far far away
    Yes. I clear crash data with op-com for over 7 cars.
    Works perfectly.
    PS: Use op-com 090714_EN
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    Nov 2009
    Croatia europe
    2) tested 3 times work fine always..
    z786's Avatar
    Aug 2009
    wen i start activation, is it supposed 2 give me a message?
    these worry me abit
    (56) - Present
    (00) - Present
    also im abit confused, can any1 hee tell me wat parts i need 2 activate by looking at the dtcs???
    thanx
  11. #11
    Mar 2010
    west midlands
    i dont to make this sound as dont know what you am doing but i helped a mate repair a astra h few years ago on a 55 plate we had a simlar problem and we got fed up of changing parts make you have changed everything thats needs changing also i was told by vauxhall but the airbag control module is only good for two deployments after that it scrap it might be worth checking just in case its been deployed before.
  12. #12
    these worry me abit
    (56) - Present
    (00) - Present
    thanx
    There are some SDM units that crash data cannot be erazed with OPCOM or TECH 2 clear deployment record function. Last week i had an YQ ident unit. With OPCOM i had the same problem with you. After activation B1000 and B0051 cannot be cleared, so i tried with tech 2. Tech 2 showed crash data cannot be erazed - no more valid usage period. So the only option is via onboard programmer.
  13. #13
    Jul 2010
    Hello,
    I need pass for this dump, or better - if some of you have dump for Astra H MY 2008
  14. #14
    juozas10's Avatar
    Jan 2010
    LT
    Quote Originally Posted by emes125 View Post
    Hello,
    Hi.
    Please post your the original crash dump,you need fix the original dump then it will works.
    Best regards.
