Results 1 to 5 of 5
    Default Starview 6 help needed
    I have just bought a HD starview box and have tried to set it up but it only gets a few channels which work and the others have been found but have no signal. Is there a way to get all channels to work without new software being downloaded onto it ? thanks
    Jan 2009
    starview 6 in not an HD box the strarview combo is HD yes you will need to flash your box unless your supplier has done that for you
    alex
    yeah sorry I must have the combo one then. which download do I need to get for the box to work with all channels ? thanks
    Default Starview HD Combo
    Yes we do have a Starview HD combo, it is brand new, all the channels including pay ones are visible and scanned in but none of the pay ones work they are scrambled. Could it be that the software is already loaded and can be accessed by using the remote or will we need to download some codes or software , if so from where.
    Can anyone help ?
    Jan 2009
    check the stickies above in the combo section firmware and guides there
    also as the combo is cable and satellite then it helps to say what you are connected to cable or sat
    and with all the areas going off at present it also helps to say where you are about just incase your area has gone to N3
    cheers alex
