Results 1 to 15 of 20
    Question RNS-D Audi Decode
    Please help Decode RNS-D (Navigation+)
    4D0 035 192H
    BNO 0001
    1. I used "VAG Navi.rar" with the forum
    2. Read dump 24C32 (№1)
    3. Changed dump (№2)
    4. Programmed dump № 2 and Verify
    Montreal, but the code is not suitable . What to do? Tell my what I'm doing wrong?
    prusony's Avatar
    Belarus
    Quote Originally Posted by SnipeR24 View Post
    CODE to original DUMP 1568
    NO NEED!!
    Changed dump (№2)
    ((dumps are not compatible))
    Minsk, Belarus
    Quote Originally Posted by prusony View Post
    NO NEED!!
    Hi friend!
    May be You have calculator for this NAVi?
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Dumps are compatible because are from same Navi only code changed.
    You need to disable verify before start read/write eeprom.
    exxl's Avatar
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    and try few times, even with original carprog navi decode package you have sometimes to try few times before the navi gets the code you have entered.
    regards
    Not working!!!
    prusony's Avatar
    Belarus
    Not working!!!
    -= 1568 =- Not working ??????
    I'm sure !!!!!!! CODE correct !!!!
    SnipeR, How many (+) wire you connect to this navi?
    All 3 ?
    +12, +12 After starting, SAFE
    cristi_onofrei's Avatar
    Iasi, Romania
    maybe "SAFE PIN"??
    episcop's Avatar
    Portugal
    Help with code Audi Navigation Plus
    4B0 035 192 F
    my FIS 24c32
    prusony's Avatar
    Belarus
    Quote Originally Posted by episcop View Post
    4B0 035 192 F
    my FIS 24c32
    Enter -= 0934 =-
  13. #13
    Top Poster incar's Avatar
    UK
    Hi! How You calculate the code from dump? On NYO4 they ar not all sopported! I remember that some while a go i heaw seen that it cud be done from thous 3 dump strings on regular hex calc ,but how?
  14. #14
    prusony's Avatar
    Belarus
    Quote Originally Posted by incar View Post
    It simple - i have calculator from dump ....
  15. #15
    What program do you use to read the dump?
    And if I were to read it would you be kind enough to calculate to code for me?
    Mark
