Results 1 to 4 of 4
Thread: Vito dashboard
    Default Vito dashboard
    Hello, i have IC of Vito (W638) and i cannot find the wiring diagram for it. On the back of the cluster there are two 12 pin connectors, named "Stecker 1" - this connector has black color and "Stecker 2" - this connector has white color. I would appreciate any help, thanks in advance!
  2. The Following User Says Thank You to nevermatters For This Useful Post:
    McDowell (17th January, 2020)
  3. #2
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Stecker 1 (Black) 18 pins
    9 18
    1 10
    1: Kl 31 Masse (GND)
    2:
    3: Geber Tachometer
    4: Kl. 30 Batterie Plus (Sicherung F17)
    5:
    6:
    7: NC
    8: CAN1-Low
    9: Kl. 15 Ignition Plus
    10: K-line
    11:
    12:
    13:
    14:
    15: CAN1-High
    16: CAN2-High
    17: CAN2-Low
    18:
  4. The Following 6 Users Say Thank You to lupu_sandu For This Useful Post:
    alclot (18th January, 2020), byyoyo (15th February, 2022), geocity (2nd January, 2016), juzzac (3rd October, 2015), McDowell (17th January, 2020), TeiS (1st November, 2023)
  5. #3
    Default Some pics
    As i mentioned in the beginning , both connectors have 12 pins, not 18... Thank you for the info but i cannot use it. I made some pictures of the IC:
  6. The Following User Says Thank You to nevermatters For This Useful Post:
  7. #4
    McDowell's Avatar
    Feb 2019
    Zamunda
    I am after this cluster pinout as well, Anyone?? Thanks a lot
  8. The Following User Says Thank You to McDowell For This Useful Post:
