Results 1 to 12 of 12
    dyc's Avatar
    Jan 2010
    Default audi 4f bmk injectors programming
    im trying to program new injectors on audi a6 2006 bmk engine and after entering codes of injectors the communication with ecu is broken ,do I need security access code for reprogramming ? Im using Vas
    Turn off battery to see if made reset,after connect tool again...
    dyc's Avatar
    Jan 2010
    I try it before not helps
    Aug 2009
    Netherlands
    Only experience with vagcom, that works fine. No login code.
    Try to connect with other modules,abs,central locking... to see if diagnostic line is ok
    If line ok
    Disconnect ignition about 1 minute.
    Turn on ignition...start diagnosis,by OBD mode.
    If ok after,repeat the process in direct mode.
    If no,repeat the sequence again
    regards
    Mar 2010
    OK I try it before not helps
    Quote Originally Posted by muhad00 View Post
    Do you have same problem?
    Member sergiompais's Avatar
    May 2010
    Portugal
    Post
    Quote Originally Posted by dyc View Post
    If you're using VAS, go to "Guided functions" and then follow instructions under "engine module" for injector programming/adaptation. worked for me everytime (tested on VAS 14 and 17).
    dyc's Avatar
    Jan 2010
    Im doing it with "Guided functions" Vas v15 ,I have communication with car every module engine too ,but when program ask to write data to ecu communication is cut. Its strange becouse I can not change milage with magic dash can in ecu which I made many times in other a6 , reading works.
  11. #11
    Sep 2009
    I had a similar problem a few years ago. Then I find out the ECU was tuned and,maybe, after modify the value for injector it crashes , due to the modify software. I had to rewrite the ECU soft ,from another one ,and to readapt it to immo.
  12. #12
    dyc's Avatar
    Jan 2010
    I made it with vcds without any problems so I think vas is better for guided fault searching vcds easy to use
