Page 1 of 3 123 LastLast
Results 1 to 15 of 42
    Default file to big not fixed
    dm800 and dreamup all ver. could not talk to each other even with the enforcer
    I tried all the lead but no solution now the light of the ethernet went blank "no light" if any one solved thi prblem please post for me and the others with same problem
    I am sorry but had this problem and comunicate with the expert in this forum but no solution till now
    bubbles69's Avatar
    Somehwere in the South East
    have you tried the patched dreamup witch i posted a few weeks back..!!
    yes but not working I'll com with solution
    bubbles69's Avatar
    what does the display say? the dreamup i posted puts it back in flashing mode if you have no CA error, what error do you have?
    it bootuo till the end then transparent bar under it is 3:03
    bubbles69's Avatar
    sounds like wrong image installed for bootloader, can you flash via webshell still?
    or are you saying its stuck on first screen dream multi media?
    I have a similar problem with my DM800HD. When switched on the display shows "Error". With a serial cable I try Dreamup and get the message "No CA found...". With the enforcer I can try to flash but get the message "File too big" even if it is the smallest file I can find.
    Any suggestions?
    John Leo
    bubbles69's Avatar
    Can't understand why you guys are trying to flash the file through dreamup, you just use the patched version i posted a few weeks back and connect null modem connect to dm800 this will then put it in flash mode display the ip of the router you are connected to then on pc type the address displayed on lcd and flash..
    Hi Bubbels69
    I have already tried a patched version that did not work. Where can I find yours? I have searched for it but been unable to find it.
    bubbles69's Avatar
    i have repaired lots of no ca with the patched version i posted,, where are you getting stuck?
    The patched version I used was called
    DreamUP_patched_by_forhike_and_natas.exe.
    Is it the same one you posted?
    When I use this patched version of Dreamup, I get the message about NO CA FOUND and I cannot flash. When I click on OK Dreamup disconnects. Dreamup shows the same IP as the lcd.
    What else can I do?
  13. #13
    bubbles69's Avatar
    all you use dreamup for is for the first boot,
    click connect
    power on box
    wait for it to initialise
    once ip is displayed on dream box don't touch anything else on dreamup that is all you need to touch,
    go to pc or laptop that is connnected to same router as dreambox then type ip 192.168.**.**
    the flash thats it fixed.. i have done many no ca for people..
  14. #14
    Hi I left the box of for 12 hrs then started again and again many time but when you power off the box keep it off for at least 10 second till the box giveup and respond to you after many time of trying
    dont giveup
  15. #15
    I have done exactly as you say but explorer cannot connect to the box. I just get a mesage about site not found.
    I have tried it from 2 different PCs.
    Have you got more ideas?
