Results 1 to 4 of 4
    nairobi kenya
    Default eis damaged mcu 2 dump
    hi all
    need help to repair this dump from w202 when i try to program key with ak500 it say mcu2 data is wrong hence i cant make key
    regards
    Hi.
    Your dumps mcu1 and mcu2 - are the same.
    Try this one.
    mcu1 - is external, mcu2 - is internal CPU.
    YOUR CAR WONT START BECAUSE THE DATA RECEIVED DOES NOT BELONG TO SAME CAR.yOU HAVE TO VIRGIN ECU TO USE IT. GET W202 VIRGIN FILE AND PUT IN ECU AND THEN YOU ARE GOOD.
    Quote Originally Posted by Room View Post
    Hi.
    Try this one.
    Model:MB C-202 2,3 BENZ ; ECU type: HFM-VDO
    You need to code with STAR, Best of Luck!!!
