Page 4 of 10 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 145
Thread: ST10F280
  1. #46
    Ecuador
    Smile Nice info
    n
    Quote Originally Posted by bram380 View Post
    last update v5.0 2010-05-16 from xprog-m do it
    Hi thisis very nice info, can you share if you have more info , thank you.
  2. #47
    magnacin's Avatar
    Lavman,
    Your ECU is a newer model. It is the same ECU Peugeot 307 models 2006 and up have it is a IAW 6LPB.
    "I find your lack of faith disturbing"
    If you found my post useful, please use the "Thanks" and "Rep" buttons.
  3. #48
    magnacin's Avatar
    Mr. Mac Gyver and all DK Members,
    Thanks for your help on this matters. I have managed to read the ST10 from a Peugeot 307 IAW 6LPB using ST Flasher tool.
    Yet, I would like to ask a bit more help from you or any DK member.
    I need immo off this ECU. If that is not possible then virgin ECU dump to telecode with PP2000.
    I am attaching the file downloaded in HEX and BIN format for anyone who can help me.
    Thanks again for your help and knowledge.
  4. #49
    magnacin's Avatar
    Sorry forgot attachments
  5. The Following User Says Thank You to magnacin For This Useful Post:
    gr_diver (26th October, 2019)
  6. #50
    V.I.P. Member milanoffracing's Avatar
    Bulgaria,Sofia
    Quote Originally Posted by magnacin View Post
    Try to telecode this one with with PP2000.
  7. The Following 3 Users Say Thank You to milanoffracing For This Useful Post:
    estwood68 (9th October, 2020), gr_diver (26th October, 2019), n599fbm (7th February, 2014)
  8. #51
    magnacin's Avatar
    Dear Milanooffracing,
    I tried to convert the file you kindly sent to me to HEX file and I noticed there is a big difference in size compared to the original one.
    Virgin.hex is 1.309 kb
    Original file is 1.441 kb
    Can someone please help me on how to proceed? Do I fill in just with FF. What banks should be replaced?
    I am using ST10 flasher with K line to read and program this ECU.
    Thanks.
  9. #52
    magnacin,
    the difference in size of the files is as follows:
    the last bank of flash memory is not in virgin.hex,
    bankt 15 if I remember correctly, it is empty on this type of ECU,
    then there is no need to read and write to that bank.
  10. #53
    magnacin's Avatar
    Thanks again Mr. Mac Gyver.
    I will try to program as it is and see what turns out. I will let the forum the results sometime next week.
  11. #54
    Newbie vaterci's Avatar
    Default 036 906 034 KA how can I read st10f280 with x-prog ?
    I want read MCU (st10f280) with xprog.I cant find tx pin,rx pin,reset pin,pol.4 pin,vcc pin and gnd pin in ecu mainboard.Please see attachment picture and sent to me connection diagram for xprog..
    036 906 034 KA MAGNETTI MARELLI IAW4TV.KA
    thanks..
  12. #55
    magnacin's Avatar
    Try these pictures an probably will help you.
  13. #56
    Thank you for your interest.I'm not what I wanted.Please see attachment for example manetti marelli IAW6LP2_03.
    I want magnetti marelli IAW4TV.KA ..
    thanks..
  14. The Following User Says Thank You to vaterci For This Useful Post:
    capi (23rd May, 2019)
  15. #57
    Hi, I need virgin dump MM6LPB for Peugeot 307.
    The dump of Milanooffracing dont work..
    the file...
    Thanks in advance
  16. #58
    Jan 2011
    from away
    please can you help me for program this calculator 6LPB not 6LP2 .I compare between this calculators and i find the difference in shematic electronique.
    can you help me for pinout xprog for 6lpb in this picture i put it
    thanks in advance
  17. #59
    Jan 2011
    from away
    Any help please...
  18. #60
    Default Peugeot 307
    Hello .
    I have a problem with read/Write MCU (st10f280) with xprog m .I cant find tx pin,rx pin,reset pin,pol.4 pin,vcc pin and gnd pin in ecu mainboard .
    The board is similar like in the picture ,but I did not where to conect . THE ECU is 6LP1.50 .
