the vagcom kkl 409 works well, with vagK +can I not test, but it can work well, you have to test.
Ok it's clear, with VAG-COM like this no soucy:
So Interface VAG-COM + ST10flasher software are enough?Using the OBD2 port of the car?
you can read and write the same bench, make the following connections:
pins 4 and 5 of the vagcom to GND of ECU
pin 16 of the vagcom to +12V of ECU
pin 7 of the vagcom to KLine of ecu
yes, I use wires and terminals.
Mac Gyver i think i will buy this VAG-COM VAG COM KKL USB 409.1 OBD OBD2 + LOGICIELS 5 - VAGCOM en vente sur eBay.fr (fin le 22-nov.-12 21:32:58 Paris) is it OK?
Hi mates i have a KKL so my question is: with what software did you use to read and write the ST10F280 thanks
I use this version of the ST10flasher, is the best version.
ADEL.KSHLAF (29th November, 2022), albonidao (19th March, 2019), antwnhszr (26th November, 2014), ayllon308 (20th November, 2018), conan981 (31st October, 2018), dragon100 (4th January, 2018), eagleone-two (10th January, 2015), estwood68 (9th October, 2020), foxibg (4th December, 2016), milerk (5th September, 2015), missfixit (28th February, 2015), OFFIMO (31st January, 2015), pablobonome (7th December, 2016), raskolnikov1975 (21st February, 2019), ratso77 (27th April, 2019), shanektm450 (26th September, 2017), Silver740 (1st August, 2019), ZYX (25th September, 2013)
can be with this terminal or other type, it is important to stay well connected and do not touch adjacent pins, leaving the short circuit.
the VAG-COM that showed works fine.
The two 560R resistors that i must place in the ECU following the photo that you sent me are essential?i can't read or write without them?
yes are essential.
