Results 1 to 3 of 3
    Default 97 maxima no start
    i have a 97 maxima,after i swapped the engine ,it doesnt want to start i mean no spark no start...battery is good,starter is new any idea will be appreciated
    DK Veteran teuton's Avatar
    Mexico
    More info please in order to help you, did the "new" engine run before? Is it same type, same year? Are the wiring looms/conectors the same? I suppose the starter turns engine over, do you get an rpm signal in live data with scantool? How about immo, did you just change engine or ecu as well, so that it might be it has to be programmed to immo?
    just tell a little bit more.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Anmed's Avatar
    St.Petersburg, Russia
    The wire on the car body from the transmission! Check it! Standard sore, better to duplicate the wire.
