Results 1 to 3 of 3
Thread: codes
    Apr 2008
    Default codes
    does any body know if there are codes for dw uk 1.6.5 or would i be better off re flashing the box with v2.0 uk then updating with new codes?
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    The dw 1.6.5 image has the tuxbox commander plugin via the BLUE button menu. You shouldn't need to update the image just to enter the new keys.
    Apr 2008
    liverpool
    blue button on remote select tuxbox comander, in the righthand box select "VAR" then select "KEYS" now goto "KEYLIST TXT" and press number 4 on your remote now keylist's should appear. press ok now the top line should be bold use your remote and to move red cursor and change keys were needed. press ok on your your remote then exit save (red button) exit save (red button)... now you will most probably need to restart you evocamd... blue button dw dream menu goto EMU press ok to start cams...
