Results 1 to 2 of 2
    Default Need help with four OBD2 codes
    I have a 2007 Saab 9-3 2.0T with 15,500 miles. The car has a misfire, an intermittent no start situation, and intermittent stalling while driving, along with some other problems. The car has been 13 times to the dealership for a total of 102 days to try and resolve those issues with no luck. On May 14, 2010 I took the car once again to the dealership because of the same problems. I received a call yesterday from the Service Department in which they said that the car was presenting with 4 OBD2 codes that it had never had in the past. The codes are the following: 1)B0092, 2)B1440, 3)U1501, and 4)U2105. Can any of you guys tell me what those codes are and what could be causing them to show up?
    west midlands
    b0092 is passenger side restraints sensor fault
    b1440 is a power mode master input circuits mismatch - cim / ign fault
    u1501 is implausable message data bcm - cim
    u2105 is can bus data communication error to ecm
