Results 1 to 11 of 11
    Default Win XP partitions swapped, xp wont boot....
    Have strange problem with my PC.... Used to work fine, but one morning it stopped to boot from strange reason. I got message NTLDR missing, press CTRL+ALT+DEL.
    After checked boot order in bios etc... I have ran xp recovery console to see what was going on, and have found out that partitions on my HD are swapped. What was partition C: is now D: and vice versa. Offcourse I had my xp at c: so now it wont boot after it considers my formerm D: as C: now......
    I cannot google anything how to fix that thing. Found many instructions how to swap drive letters in windows, but I cannot get to win. I need to use recovery console etc. swap my drives back and repair windows so it can boot again.
    I do not want to loose any data from harddrive, as data are still there and can be seen via recovery console.
    Many thanks
    dasteph's Avatar
    Nov 2008
    north east
    can you go into the bios and switch the drive letter from c to d.
    no, i do not have any options like this in bios....I only can change boot order, nothing else. I am wondering why computer had swapped letters for these partitions itself......
    just unplug the drive you dont want and try, or if you?r drive e Sata try to configure on bios the frist sata.
    Sorry my bad english but i?m portugues.
    I only have one harddrive, but it is divided into two partitions c: and d:
    So there is no further configuration possible in BIOS, as BIOS recognizes only one disk drive.
    dasteph's Avatar
    Nov 2008
    north east
    the following link will tell you how to change the drive letters using a floppy boot disk if you have a floppy drive.
    The computer does not start after you change the active partition by using the Disk Management tool
    this is the only solution i can find hope it is of some use.
    Many thanks,
    I will try it and report back.
    Feb 2009
    ntldr is missing,its a file thats been deleted and untill you put it back it wont boot,i had same problem,i managed to find and download a file to a cd/and usb which then booted windows ok,but couldnot manage to get this back onto the hard drive,so just booted from usb all the time.cant remember what site i obtained it from but all the info and instructions was on there.i still have the ntldr is missing file on a cd i think,if i have your quite welcome to have a copy...of to see if i still have it
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    Newbie ib_linker's Avatar
    UK
    Default XP Partition problem
    Boot with your XP CD & enter command prompt - run fdisk & set active partition to C:
    Feb 2009
    Quote Originally Posted by dik View Post
    thats the one i followed
