Just had success with Nasratech opel pin reader on 2004 meriva Z16XE.
Nasratech have also sent me list of models covered and working at the moment its attached to thread.
You need every tool in the book, to do this auto locksmith job.
obd
Have you got the update yet ?
cheers Joe
Here is nasratechs list after update, ive been told it will be released monday. I will post my findings asap.
Just used it to read security code of donor ecu on car and reset unit on car. Again it was a vectra B z18xe.
Had to use opcom to program it but the guys at nasratech have assured me, after getting ALL security codes working, they will be getting the immo functions fully functional also.
Happy days.
hi can you please do some work on a transponder box with this equiptment, like read a security code off one or reset one ready to be used as i am thinking of buying this equiptment but dont know if you can read codes from the immo box but am sure that they can be reset without having the original code
many thanks
My opel pin reader by nasratech has just been updated not tested any yet myself but will keep you all informed heres the list from them:
New supported functions with the first update:
Total Odometer Counter,
Total Engine Running Time,
Change Total Odometer Counter for Can based cars
New Supported Models with the first update:
AGILA Z10XE Motronic M1.5.5 KWP2000
AGILA Z10XEP Motronic 7.6.1 KWP2000
AGILA Z12XE Motronic M1.5.5 KWP2000
AGILA Z12XEP Motronic 7.6.1 KWP2000
AGILA Z13DT Multijet 6JO KWP2000
ASTRA-F X16XEL Multec (F) KWP2000
ASTRA-G Y17DT HDRC KWP2000
ASTRA-G Y17DIT HDRC KWP2000
ASTRA-G Z12XE Multec S (F) KWP2000
ASTRA-G Z14XE Multec S (F) KWP2000
ASTRA-G Z16SE Multec S (F) KWP2000
ASTRA-G Z16XE Multec S (F) KWP2000
ASTRA-G Z18XE Simtec 71 KWP2000
ASTRA-G Z20LET Motronic M1.5.5 KWP2000
ASTRA-H Z12XEP Motronic 7.6.1 CAN2000
ASTRA-H Z14XEL Motronic 7.6.1 CAN2000
ASTRA-H Z14XEP Motronic 7.6.1 CAN2000
ASTRA-H Z16LET Motronic 7.6.2 CAN2000
ASTRA-H Z19DT EDC 16C9 CAN2000
ASTRA-H Z19DTL EDC 16C9 CAN2000
ASTRA-H Z20LEH Motronic 7.6.1 CAN2000
ASTRA-H Z20LEL Motronic 7.6.1 CAN2000
ASTRA-H Z20LER Motronic 7.6.1 CAN2000
CORSA-C Y17DT HDRC KWP2000
CORSA-C Y17DTL HDRC KWP2000
CORSA-C Z10XE Motronic M1.5.5 KWP2000
CORSA-C Z10XEP Motronic 7.6.1 KWP2000
CORSA-C Z12XE Motronic M1.5.5 KWP2000
CORSA-C Z12XEP Motronic 7.6.1 KWP2000
CORSA-C Z13DT Multijet 6JO KWP2000
CORSA-C Z14XE Motronic M1.5.5 KWP2000
CORSA-C Z14XEP Motronic 7.6.1 KWP2000
CORSA-C Z16SE Multec S (F) KWP2000
CORSA-C Z18XE Simtec 71 KWP2000
CORSA-D Z10XEP Motronic 7.6.1 CAN2000
CORSA-D Z12XEP Motronic 7.6.1 CAN2000
CORSA-D Z14XEP Motronic 7.6.1 CAN2000
CORSA-D Z16LEL Motronic 7.6.3 CAN2000
CORSA-D Z16LER Motronic 7.6.3 CAN2000
MERIVA Y17DT HDRC KWP2000
MERIVA Y17DTL HDRC KWP2000
MERIVA Z13DT Multijet 6JO KWP2000
MERIVA Z13DTJ Multijet 6JO KWP2000
MERIVA Z14XEP Motronic 7.6.1 KWP2000
MERIVA Z16LET Motronic 7.6.2 KWP2000
MERIVA Z16SE Multec S (F) KWP2000
MERIVA Z16XE Multec S (F) KWP2000
MERIVA Z18XE Simtec 71 KWP2000
SPEEDSTER Z20LET Motronic M1.5.5 KWP2000
TIGRA-B Z14XEP Motronic 7.6.1 CAN2000
VECTRA-B X16XEL Multec (F) KWP2000
VECTRA-B Z16XE Multec S (F) KWP2000
VECTRA-B Z18XE Simtec 71 KWP2000
VECTRA-C Z16XE Multec S (F) CAN2000
VECTRA-C Z19DT EDC 16C9 CAN2000
VECTRA-C Z19DTL EDC 16C9 CAN2000
ZAFIRA X16XEL Multec (F) KWP2000
ZAFIRA Z16XE Multec S (F) KWP2000
ZAFIRA Z18XE Simtec 71 KWP2000
ZAFIRA Z20LET Motronic M1.5.5 KWP2000
ZAFIRA-B Z19DT EDC 16C9 CAN2000
ZAFIRA-B Z19DTL EDC 16C9 CAN2000
ZAFIRA-B Z20LEH Motronic 7.6.1 CAN2000
ZAFIRA-B Z20LEL Motronic 7.6.1 CAN2000
ZAFIRA-B Z20LER Motronic 7.6.1 CAN2000
INSIGNIA A20DTC Bosch EDC17-05 CAN2000
INSIGNIA A20DTJ Bosch EDC17-05 CAN2000
INSIGNIA A20DTH Bosch EDC17-05 CAN2000
I tried on a 2007 Corsa'D Engine code Z12XEP got a few errors when trying to read pin but after a few trys it read pin ok.
It seemed to work better by reading DTC first then Read pin.
Nasratech are looking into the error.
But looking good so far. will test more and post my outcome.
Hopefully by having seen the responses on the forum their customer service will improve.
In my expereience, ther customer service towards me, has been excellent. Had a few small problems that they where straight on teamviewer trying to solve. But hopefully after the update, most small glitches have been resolved, im looking forward to testing and hopefully posting my positive findings.
sorted Obd , just did as you said,updated right away.
cheers Joe
Tried for over 40 minutes on a corsa D 2009 z12xep with no success,could`nt try any longer as i had to get to my next job
Joe
What was happening when you tried to read pin . were you getting an error on screen.
Did you try reading DTC first then try to read pin in ecm.
Oh and did you have a hassle getting the plug to fit the 16pin connector
Have you both noticed, you have to be connected to internet now to read pin. I was doin z18xe and it said check internet connection. So i had to connect to internet before it would read pin.:
