Had a quick look about, was wondering what the default pin code is for the paretal locks, or if anyone has a guide on how to set this up.
DM800HD With blackhole image
Cheers
Cheers
Default pin is 0000 and you can download the user guide here
Freck
if your lock is activated and you have forgot your pin, you can find it use ftp to your box, go into Enigma2 folder, then into settings folder and scroll through it you should find it there. Should be a line that reads (perental lock setuppin 1234) or whatever it is.
Good luck
will look at that thanks
i tried this,
my Enigma2 folder is in a folder call etc.
and their is no folder with settings, only a file called settings
when i open it i do not get a line line that reads (parental lock setuppin 1234)
and it still keeps asking me for a password., please help
search for setuppin=
after the = sign u will see ur password in digits
(1234) is just a example the 4 digits will be whatever is set. Just as a matter of interest has the parental lock been set when you went through the set up, if not you just need to set it up. If you have set it up, and if you cant find it in the folder I suggest, just be patient it will be there. I had the same problem.
when i got the box, i did not set-up a pin.
the guy i got the box from said he did not set up a pin either.
i was moving channels and by mistake i put nick.jnr as parental lock , and my daughter is going crazy FAV channel.
when i go into \etc\enigma2
their is a file called settings this is what i get in the file
config.misc.languageselected=false
config.misc.rcused=1
config.misc.firstrun=false
config.misc.initialchannelselection=false
config.misc.defaultchosen=false
config.misc.startCounter=5
config.misc.videowizardenabled=false
config.timezone.val=(GMT) Greenwich Mean Time : Dublin, Lisbon, London
config.Nims.0.diseqcA=282
config.Nims.0.diseqcMode=single
config.Nims.0.configMode=simple
config.Nims.0.advanced.sats=282
config.Nims.0.powerMeasurement=false
config.tv.lastroot=1:7:1:0:0:0:0:0:0:0type == 1) || (type == 17) || (type == 22) || (type == 25) || (type == 134) || (type == 195) ORDER BY name;
config.tv.lastservice=1:0:1:2332:803:2:11A0000:0:0 :0:
config.av.generalAC3delay=-75
config.av.policy_169=scale
config.av.videorate.1080i=60Hz
config.av.policy_43=scale
config.av.defaultac3=true
config.av.videoport=DVI
config.usage.show_event_progress_in_servicelist=tr ue
config.usage.blinking_display_clock_during_recordi ng=true
config.usage.multibouquet=true
config.ParentalControl.setuppinactive=true
config.ParentalControl.configured=true
config.ParentalControl.servicepinactive=true
config.ParentalControl.retries.setuppin.tries=0
config.ParentalControl.retries.setuppin.time=12781 83381
config.ParentalControl.retries.servicepin.tries=0
config.ParentalControl.retries.servicepin.time=127 8181373
config.lcd.standby=0
config.lcd.bright=0
config.recording.margin_before=0
config.recording.margin_after=0
as you can see config.ParentalControl.servicepinactive=true is active, but no pin code..
is this stored anywhere else, or can i replace this file is someone sends it to me. or add a entry?
i have done a search for setuppin= but no luck, as it think this is the text and not a file.
please help.
hi guy, sorted
i changed
to
config.ParentalControl.setuppinactive=false
config.ParentalControl.configured=false
config.ParentalControl.servicepinactive=false
and it turned off pin service and allowed me to set me pin.
now when i got to the file and edit it shows
config.ParentalControl.servicepin.0=**** my new pin is their.
thanks for your all your help
hi
i had the same problem before regarding this
you best solution is
menu
setup
startwizard
use wizard to set up basic features
press ok once
do u want to install
no
do u want to service scan
no , scan later manually
do u want to enable parental conteol
yes
then follow screen instruction
