how is this step done:
4. log into webshell on pc using the 192.168.x.xxx address on LCD disply and flash as normal
Just type the ip addy of the box into your web browser mate
Hope this helps ........Paul
http://www.digital-kaos.co.uk/forums...-dm800-122157/
PAUL
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cablescrew you nag3
Great little tutorial. Got this patched dreamup working with wine on ubuntu. The following was necessary:
1.
in ~/.wine/dosdevices/
ln -s /dev/ttyUSB0 com1
(or whatever you have as your serial port instead of /dev/ttyUSB0)
2.
edit ~/.wine/system.reg
add to the bottom of the file:
[HKEY_LOCAL_MACHINE\hardware\devicemap\serialcomm]
"COM2"="COM2"
"COM1"="COM1"
[HARDWARE\\DEVICEMAP\\SERIALCOMM] 1131331688
"COM1"="COM1"
"COM2"="COM2"
more info here:
Wine Registry - Wine-Wiki
3. Fire up the patched Dreamup via wine and follow the rest of the tutorial on this thread.
Thanks!
I have this error on the llittle screen and I can't even get dreamup to recognise my box. " No ca found " message appears after a couple of seconds. I have it connected via a prolific usb to serial adapter and have COM1 selected happend after pulled the power cable out after the box froze Could someone help me please?
That sounds like your USB adapter is not configured properly, are you sure it's configured for COM1.
Thanks lincsat. I forgot to mention I am using a clone box. Installed the usb drivers and get dreamup to see the COM1 port but when I plug in the box it doesn't recognize the box. When I use enforcer and try to flash it with a new image I get the file to big message. Do you think the serial connector on the box might be broken? I bought it from ukdreamshop. Thanks
Still can't get dreamup to communicate with the box even with a new cable from maplin. I'm trying everything I can without having to returning but I think it's dead/bricked.![]()
don't give up try this http://rapidshare.com/files/441712505/DCC.rar connect via routeror turn on and off the box a few times when it tells you to now connect your derambox
read the tut, if it dont see the box try a pc with a serial port if still the same the rs232 port is not working on the dm800
Old pc with serial port will not boot or I can't see any pic or screen. Tried everything but that, will try to get a pc with a serial port. o well Thanks![]()
dm800 must be connected through a router otherwise it wont get ip so you can log into the webshell
I do have it plugged in to the router and I have tried a desktop with a resident serial port and can the box just won't go into flash mode. Like you said bubbles, I think the dm800 has a broken rs232 port.
yes soon as you click connect in dreamup and power on in the dialouge box you should see found : dm800
do you get this?
