Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    May 2010
    Default mondeo glow light & stall
    hey chaps,
    was hoping to get some advice this evening,
    i have an 02 ford mondeo 181k
    recently whilst doing 70mph +, the glow light flashes and engine loses power and turns off, after pulling over the car restarts and away i go. this can happen 2 maybe 3 times a journey on the mway and occurs mostly after accelerating from 70 ish
    took it to garage who put it on a diagnostics machine and it came up with error "1120 unknown error" (error might not be exactly right)
    i've done a few searches and have found a range of causes, mechanic seems to think its a a fuel injector pump and thinks it could be about ?500 (he's going to have a closer look tomorrow)
    internet searches show that it seems to be a fairly common problem and some suggest its could be a crankshaft position sensor (mechanic said the car wouldn't restart if this was the case), or even a slight fuel leak around the injectors.
    others who have taken their car to ford generally get quoted ?1k for a new fuel injector pump
    wanted to get the opinion of the folks on here, is it really the fuel injector pump? are there other possible causes what kind of cost am i looking at?
    any help much appreciated
    May 2010
    hi seen this at work firstly check injector spill off as we have had this causing this problem the other thing we found cause a simler problem is the egr valve firstly is yours vacume or electronic controlled has i said had this a few times and found it to be one of these problems
    May 2010
    Quote Originally Posted by scenic View Post
    thanks for the reply
    no clue if its vacume or electronic how would i tell?
    its a 02 ford mondeo 2.0l tdci zetec duaro
    if that helps
    Ashraf6119's Avatar
    Nov 2009
    UK
    My advice is before you start replacing any parts get some body to Diagnose your Car properly and post the fault codes here.
    As per your explanation it looks like you have a boost pressure fault. it could be a sticking Turbo problem or any vacuum pipe.
    Hope This Helps
    Ash
    May 2010
    you mast do injector overflow test
    Feb 2010
    You need to get it diagnosed properly mate.
    If the glow plug light flashes there will be a fault code.
    The glow plug light flashes for many reasons on Mondeo TDCi.
    Some common faults are:
    1. Camshaft position sensor - Modified sensor and harness available from Ford
    2. Injector malfunctions
    3. Fuel Pump problems
    4. Crankshaft position sensor - Usually caused by the dual mass flywheel breaking up and the crankshaft position sensor collects all the debris from it, this then masks the crank pickups at high RPM.
    These are just a few problems, you really need to get it diagnosed or at least fault codes read out of it with a reliable code reader.
    May 2010
    cheers fellas,
    i'll get the mechanic to let me know his diagnosis tomorrow morning and report back,
    it won't be the fly wheel breaking up, had this replaced about 6 months ago
    thanks again
    May 2010
    problem:
    1 - injectors
    or
    2 - CMP
    May 2010
    guys
    mechanic stuck it on a diagnostic machine and it came with with the following errors
    P1211 - injector control pressure
    P0251 - injector pump
    can anyone enlighten me on these codes and likely fixes with costs, waiting for mechanic to call me back
    cheers
    May 2010
    to check the filter of fuel, quality of fuel, filings of metal in a fuel tank
    if it is well, test of the pressure of injectors and damaged to exchange. to programme injectors after the exchange
    attention !! brown plug in the pump of fuel during the test taken, plugs of injectors unfastened, to install measuring
    minimal pressure it 25 MPa
  11. #11
    May 2010
    Quote Originally Posted by moskito-tom View Post
    cheers MT, i take it that's outta the manual?
  12. #12
    May 2010
    I don't have. I have the knowledge about it
    in what problem. do the test of the pressure. common rail in Mondeo MK3 is easy
  13. #13
    justy22's Avatar
    May 2009
    UK
    I've heard of this problem before in high miler Mondeos its something that breaks down in the injection pump and the particles end up in the injectors, having to re boot and go is the symptoms along with the light
  14. #14
    could be as simple as a chocked fuel filter,when was this last changed?
  15. #15
    May 2010
    Quote Originally Posted by r6eck View Post
    had a service about 5k ago, i think it would have been changed then
