Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Mosc
    Default I need coding ABS brakes VW GOLF V '2007
    Hello . I have a problem with VW Golf V, TDI, '2007 year,
    Control Module ABS is not code... Hand brake light is Blinking and squeals buzzer.
    VIN :WVWZZZ1KZ8P050460
    Please me help with coding , Thanks
    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 AD
    Component and/or Version: ESP MK60EC1 H35 0104
    Software Coding: 000000000000000000000000000000000000
    Work Shop Code: WSC 01316
    1 Fault Found
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 30446 km
    Time Indication: 0
    Freeze Frame
    Count: 16391
    Count: 0
    Count: 8192
    Count: 195
    Count: 45568
    Count: 0
    Count: 0
    Count: 0
    Advanced Identification :
    Identification: TT1-000
    Revision: 00H35001
    Date: 05.07.08
    Manufacturer number: 0302
    Test stand number: 015D
    Flash Status
    Programming Attempts(application): 0
    Successful Attempts(application): 0
    Programming Status: 00000000
    Flash Date: 2000.00.00
    Flash Tool Code: 00000 000 00000
    Misc.
    Hardware number: 1K0 907 379 AD
    Workshop System Name: -----
    Mosc
    This is long coding ? I need long coding control module abs brakes ...
    I have " Soft Coding : Long Coding "
    The site Rosstech is probably only a simple coding ? ?
    http://img80.imageshack.us/img80/2594/golf5scan.jpg
    http://img19.imageshack.us/img19/7449/absg5.jpg
    mastaflex's Avatar
    Jan 2009
    FR47310
    hello:
    click on long coding helper it will suggest you option but you need to refer to PR codes on car data plate.
    Mosc
    Lcode helper is not display suggest when I tried coding...
    Ashraf6119's Avatar
    UK
    Can you try this coding 0001025 see if its any good
    Ash
    Mosc
    But apparently there is Long Coding, The service provides information that the Control Module is mounted by another car. Is the Control Module can I encode this car??
    hjulet did you solve this problem? i have the same problem in golf v variant from 2009. i have some codings from internet (many people posting logs from vcds...) but probably I need Security Access KEY...
    anyone can help?
    thanks, meli
    Have you tried to code ABS with internet examples?
    Meat-Head's Avatar
    JUST SUCK THE DATA OUT THE OLD ONE, NORMALLY IT'S JUST THE PRESSURE SW FOR THE soory caps lock, t/c
    it's a 95080 eeprom from memory, not that the thing comes apart easily
    Quote Originally Posted by hjulet View Post
    1 Fault Found
    000 - -
    Freeze Frame
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 201
    Mileage: 30446 km
    Time Indication: 0
    Freeze Frame
    Count: 16391
    Count: 0
    Count: 8192
    Count: 195
    Count: 45568
    Count: 0
    Count: 0
    Count: 0
    Revision: 00H35001
    Date: 05.07.08
    Flash Status
    Misc.
    long coding
    113B401C092B0000880E02E9902200426800
    Test this encoding.
    Giorgio
    Bulgaria
    Do you have a solution? I have the same problem with the same control module. How to coding?
  13. #13
    May 2009
    Quote Originally Posted by oem View Post
    hello,
    how you solved it? I have the same problem
  14. #14
    Junior Member vdubman1's Avatar
    OHIO USA
    need vas pc and use guided fault finding and can recode by using the subroutine abs module coding!!
  15. #15
    May 2009
    unit in question MK60EC1 do not think you can encode without access GEKO online.
    What the experts say about it?
    I tried unsuccessfully to encode with VCDs, VasPC vagCanPro..etc..
    Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
    Control Module Part Number: 1K0 907 379 AE HW: 1K0 907 379 AE
    1 Fault Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 183
    Mileage: 1048575 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 12
    Count: 4608
    Count: 195
    Count: 44544
    Count: 65280
    Count: 0
    Count: 0
