Page 28 of 89 FirstFirst ... 1823242526272829303132333878 ... LastLast
Results 406 to 420 of 1332
  1. #406
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    I having problem with using "SAVE' command in a new software
    the codes is running on the IDE but when I compiled and run in UPA the compiled codes, the save button take no action
    I think there is a bugs on this software
    also there are some Runtime errors
    The command "If not Read/ProgramDevice" is now working on this new software
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  2. #407
    Russia
    Hello! Could you help with the algorithm Yazaki? I want to write a script for Mitsubishi lancher 9. Thanks)
  3. #408
    The old script does not work, must be rebuilt, very painful.
  4. #409
    hcip's Avatar
    Quote Originally Posted by bolonc View Post
    it not happen to me, all of my old scripts are running, udx or uds files. I test it all first when I installed the software and everything works
  5. #410
    rj22's Avatar
    UPA-USB Device Programmer v1.2.0.57 Beta 09-Sep-10
  6. #411
    I have a chinese clone of the UPA. Clone will work with the new version of the soft?
  7. #412
    Member jawnuolis's Avatar
    Ireland, Dublin
    Quote Originally Posted by launcer View Post
    don`t risk it can be china clone killer
  8. #413
    hcip's Avatar
    you are right,
    there is a bugs in loading the scripts
    sometimes it run and sometimes doesnt load and give the errors device or procedure cannot be found even the device or procedure is in the scripts or in menu
  9. #414
    hcip's Avatar
    New Version was released, still in Beta version
    Please log in
  10. #415
    near Strzyzow
    Scripts doesn't work. "Read Error"
  11. #416
    melcool's Avatar
    SPACE
    all scripts work for "installing"!!Not tested with all devices!
    Tested VW1 immo script with HC05B16:
    Read device ok
    Read VIN and Pin with script ok
    Make immo off (write) I get error
    New software has bugs!
    Last edited by melcool; 14th September, 2010 at 12:12 AM. Reason: tested with device
  12. #417
    hcip's Avatar
    A Testing for a new Software of UPA
    Happy new Scripting
  13. #418
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    @hcip
    it seems ok
    have not 93c56 to confirm all but script running ok with my upa
  14. #419
    hcip's Avatar
    Default New Script Fixed
    The Script Posted has a bug on saving the files
    now it was corrected
    This script can only use for New Software of UPA-USB
  15. #420
    hcip's Avatar
    Default Testing For Ford
    Here is a testing for Ford
