Page 49 of 89 FirstFirst ... 39444546474849505152535459 ... LastLast
Results 721 to 735 of 1332
  1. #721
    Junior Member zfkd's Avatar
    Default MED9.1
    MED9.1 Info
  2. #722
    Default MED9.1
    new MED9.1
  3. The Following 8 Users Say Thank You to zfkd For This Useful Post:
    ciptel07 (25th December, 2013), darwins (22nd April, 2015), eleeinidis (9th May, 2017), hbalazs (30th August, 2020), hmagga (21st June, 2019), Jashmine1983 (6th December, 2014), mariusz971 (8th August, 2013), pintobraz (29th July, 2014)
  4. #723
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    hi all ... please I need some one to modify this attached sample script of (opel Immo , upa software V1.1) . I need to be able to use this sample script on UPA software V1.2 without connecting the UPA programmer .. is it possible ??
    if yes ?? then please modify the attached script then reupload it .. thanks in advance
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  5. The Following User Says Thank You to pinkfloyd5eg For This Useful Post:
  6. #724
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Default Sample1
    Attached.............
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  7. The Following 3 Users Say Thank You to hcip For This Useful Post:
    BBDOPAI (18th January, 2022), Jashmine1983 (6th December, 2014), pintobraz (29th July, 2014)
  8. #725
    hcip's Avatar
    Another script need to finish (Sample)
  9. The Following 6 Users Say Thank You to hcip For This Useful Post:
    audiotek (9th September, 2019), BBDOPAI (27th January, 2021), eliet2000 (4th June, 2023), Jashmine1983 (6th December, 2014), pintobraz (29th July, 2014), Tariel (1st June, 2016)
  10. #726
    Top Poster boratokm's Avatar
    Monterrey Mexico
    Default its good im tink today im finish
    Im tink today finish this script of the Master of Upa(HCIP)
    im work for this
    1.-Reflash EWS for New file .bin
    2.-Reflash SYNC for Adaptation whit change Password
    3.-HCIP work hard for search the Algo for VIN number
    And change the Vin
    i have complete but the solution of HCIP its more Easy jeje
    regards
  11. #727
    Hello friends , is it possible to write down scripts equivelent to this calculator's functions>> ONLINE CALCULATOR FOR ENCRYPTED DUMPS ,TRY IT!!
    please ,, if you are going to post script trials then make them available for SW V1.2 + can be used without connecting UPA programmer
  12. #728
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Anyone come accross this with their UPA
    5V Tests. Close J1 and press a key to continue
    Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
    Test Failed
    Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
    Test Failed
    Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
    Test Failed
    Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
    Test Failed
    3.3V Tests. Open J1 and press a key to continue
    Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
    Test Failed
    Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
    Test Failed
    Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
    Test Failed
    Test60
    Test Failed
    14 Tests failed
  13. #729
    Lithuania
    Quote Originally Posted by teerak2uk View Post
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test Failed
    Test60
    Test Failed
    14 Tests failed
    Fuse is dead
  14. #730
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Many thanks but working now just replugged it into usb a couple of times and it said
    usb boot module eeprom must be updated
    pressed ok as nothing to lose and now working
  15. #731
    May 2009
    You need to change the usb cable before you damage your programmer, it is well worth buying a good quality gold plated connections usb cable as this prevents many programming and reading problems.
    Most of the leads that come with equipment are cheap leads and not very good.
    Belkin leads are normally very good.
    Oh and by the way if my post has been at all helpfull it will encourage me to respond to posts if you remember to please press the Thanks Button
  16. #732
    hello
    have you script for change hours in ecm porsche?
    MANY THANKS
  17. #733
    Monterrey Mexico
    Default put the file
    put the file .bin for see and search
  18. #734
    hcip's Avatar
    Default Sample
    Filtering files to be open wil be good in script, I think
  19. The Following 6 Users Say Thank You to hcip For This Useful Post:
    gameiruz (5th December, 2014), hmagga (21st June, 2019), Jashmine1983 (6th December, 2014), mexjack (4th May, 2020), pintobraz (29th July, 2014), Tariel (1st June, 2016)
  20. #735
    Default porsche 997 chnge hours in ecm
    hello
    please have you script for change hours in engine control unit
    who can tell me where is the engine hours on my dump?
    To manually edit the thank you all for your help
    i have upa usb
    all thanks
    dump have 2223hours
  21. The Following User Says Thank You to diagcompteur For This Useful Post:
