Page 54 of 89 FirstFirst ... 444495051525354555657585964 ... LastLast
Results 796 to 810 of 1332
  1. #796
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Quote Originally Posted by jjrp255630 View Post
    hi,im starting to create scripts, but i need some help, where i can get a good manual with exemples in this case for change mileage in dumps?
    here is a good start point mate
    -LET'S LEARN PASCAL FOR FLEXIBLE SCRIPTING !!
    -Download 010 Editor + patch .. Merry Xmas!
    http://www.digital-kaos.co.uk/forums...w-year-247358/
    you can find many scripts as samples here on this thread to review .
    good luck
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  2. The Following 2 Users Say Thank You to pinkfloyd5eg For This Useful Post:
    clubedomodulo (24th November, 2019), gameiruz (28th August, 2014)
  3. #797
    Jun 2009
    porto portugal
    hi friends, i need help in this procedure of script, im trying to write a value in a dump, but i dont know what im doing wrong
    thanks to all
    procedure insertvalue;
    var
    a: integer;
    a:= FF;
    begin
    if not ReadDevice then begin
    sgBox( 'Read Error', 'Error', MB_OK );
    end
    else begin
    SetProgramModifiedOnly( true );
    if MsgBox( 'write value?', 'Confirm', MB_YESNO ) = IDYES then begin
    SetByteHexEdit( $AA ,a);
    RefreshHexEdit;
    end;
    end;
    end;
  4. #798
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    thanks to all
    var
    a: integer;
    a:= FF;
    begin
    end
    else begin
    RefreshHexEdit;
    end;
    end;
    end;
    The Value should be an integer and not a string
    So you need to assign it in Variable A as:
    $FF or dec 15
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  5. #799
    DK Veteran viejomatius's Avatar
    Jun 2009
    Hi Dk friends
    I need some help... I have UPA-USB ver1.2 CLONE can someone create the script for modify mileage fot CHEVROLET AVEO(68HC05H12, 93C56) AND CHEVROLET SPARK(68HC05H12) ... I don't know much about scripts then i need some help!
    thanks in advance to any help
    Car type: Chevrolet Aveo - 68HC05H12 - 2003-2005 years
    The mileage is stored in the next lines:
    0050: xx xx xx xx xx xx xx xx 02 73 84 xx xx xx xx xx
    0060: xx xx xx xx xx xx 02 73 84 xx xx xx xx xx xx xx
    0070: xx xx xx xx 02 73 84 xx xx xx xx xx xx xx xx xx
    0080: xx xx 02 73 84 xx xx xx xx xx xx xx xx xx xx xx
    0090: 02 73 84 xx xx xx xx xx xx xx xx xx xx xx 02 73
    00A0: 84 xx xx xx xx xx xx xx xx xx xx xx 02 73 84 xx
    00B0: xx xx xx xx xx xx xx xx xx xx 02 73 84 xx xx xx
    00C0: xx xx xx xx xx xx xx xx 02 73 84 xx xx xx xx xx
    00D0: xx xx xx xx xx xx 02 73 84 xx xx xx xx xx xx xx
    00E0: xx xx xx xx 02 73 84 xx xx xx xx xx xx xx xx xx
    00F0: xx xx 02 73 84 xx xx xx xx xx xx xx xx xx xx xx
    where the next bytes:
    02 73 84 - is a mileage
    ____________________________________________
    Car type: Chevrolet Aveo - 93c56 - 2005-2007 years
    0000: xx xx xx xx xx xx xx xx 0F 00 40 42 xx xx xx xx
    0010: xx xx xx xx 0F 00 40 42 xx xx xx xx xx xx xx xx
    0020: 0F 00 40 42 xx xx xx xx xx xx xx xx 0F 00 40 42
    0030: xx xx xx xx xx xx xx xx 0F 00 40 42 xx xx xx xx
    0040: xx xx xx xx 0F 00 40 42 xx xx xx xx xx xx xx xx
    0050: 0F 00 40 42 xx xx xx xx xx xx xx xx 0F 00 40 42
    0060: xx xx xx xx xx xx xx xx 0F 00 40 42 xx xx xx xx
    0070: xx xx xx xx 0F 00 40 42 xx xx xx xx xx xx xx xx
    0080: 0F 00 40 42 xx xx xx xx xx xx xx xx 0F 00 40 42
    0090: xx xx xx xx xx xx xx xx 0F 00 40 42 xx xx xx xx
    00A0: xx xx xx xx 0F 00 40 42 xx xx xx xx xx xx xx xx
    00B0: 0F 00 40 42 xx xx xx xx xx xx xx xx 0F 00 40 42
    00C0: xx xx xx xx xx xx xx xx 0F 00 40 42 xx xx xx xx
    00D0: xx xx xx xx 0F 00 40 42 xx xx xx xx xx xx xx xx
    00E0: 0F 00 40 42 xx xx xx xx xx xx xx xx 0F 00 40 42
    0F 00 40 42 - is a mileage
    ______________________________________________
    Car type: Chevrolet Spark - 68HC05H12 - 2007
    0050: xx xx xx xx xx xx xx xx 12 34 56 xx xx xx xx xx
    0060: xx xx xx xx xx xx xx 12 34 56 xx xx xx xx xx xx
    0070: xx xx xx xx xx xx 12 34 56 xx xx xx xx xx xx xx
    0080: xx xx xx xx xx 12 34 56 xx xx xx xx xx xx xx xx
    0090: xx xx xx xx 12 34 56 xx xx xx xx xx xx xx xx xx
    00A0: xx xx xx 12 34 56 xx xx xx xx xx xx xx xx xx xx
    00B0: xx xx 12 34 56 xx xx xx xx xx xx xx xx xx xx xx
    00C0: xx 12 34 56 xx xx xx xx xx xx xx xx xx xx xx xx
    00D0: 12 34 56 xx xx xx xx xx xx xx xx xx xx xx xx 12
    00E0: 34 56 xx xx xx xx xx xx xx xx xx xx xx xx 12 34
    00F0: 56 xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
    12 34 56 - is a mileage
  6. #800
    Jun 2009
    porto portugal
    hi, friends, can help me to make a procedure to do this calculation:
    for exemple, i have hex AA and need to do NOT(AA) to have FFFFFF55
  7. #801
    TABASCO MEXICO
    hello my friend , test:
    A:= $AA;
    B:= $FF
    A XOR B = $55
  8. #802
    hcip's Avatar
    Quote Originally Posted by viejomatius View Post
    Hi Dk friends
    Try this Script
  9. The Following 12 Users Say Thank You to hcip For This Useful Post:
    AMDOR (11th August, 2019), audiotek (17th September, 2019), ciptel07 (25th December, 2013), eliet2000 (4th June, 2023), gameiruz (5th December, 2014), hoangtu (26th May, 2013), Jashmine1983 (6th December, 2014), mariusz971 (8th August, 2013), martinracing (7th December, 2014), pintobraz (29th July, 2014), Tariel (1st June, 2016), viejomatius (21st January, 2016)
  10. #803
    Jun 2009
    Default CHEVROLET
    Quote Originally Posted by hcip View Post
    Try this Script
    Hi thanks for your help and your time but the script didn't work... shows an error(look atached picture), and in the script menu i don't see the option "Read Km; New Km"
    If you help me it will be very apreciated
    Thnks
  11. The Following User Says Thank You to viejomatius For This Useful Post:
  12. #804
    dashradio's Avatar
    Inafield
    Thnks
    What happens when you press "Actions" on the top row ?
  13. #805
    Thnks
    It's working mate, make sure you are using the right software version and that you have put the script file inside the device script folder, look at the attached pic !!
  14. #806
    hcip's Avatar
    The Script was compiled in the newest software realease Version 1.2 build 1.13
  15. #807
    Jun 2009
    Quote Originally Posted by pinkfloyd5eg View Post
    the script is in the correct Folder device script... and my software version is 1.2... and anyway it doesn't work for me
    Thanks...
  16. #808
    Jun 2009
    Does someone have another scripr for these chevrolet: aveo and spark mileage?
  17. #809
    hcip's Avatar
    Thanks...
    Version 1.2 Build 1.13
  18. #810
    @hcip, can you please post more scripts for vag crypto dashes C86 such as in vw polo and seat ibiza c86 crypto ?
    thanks in advance
