Page 5 of 88 FirstFirst 123456789101555 ... LastLast
Results 61 to 75 of 1306
  1. #61
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Already changed m8
  2. #62
    hi
    this is my first post.You guys are doing good job.Making upa usb programmer so good and easy to use.
    Welldone
  3. #63
    Hello. Could you try my scripts and tell me the results.
  4. The Following 5 Users Say Thank You to DrugWash For This Useful Post:
    digikeys (30th December, 2016), eleeinidis (9th May, 2017), Krittanu (1st August, 2016), LEANDRO SANDES TEIXEIRA (26th June, 2016), pintobraz (29th July, 2014)
  5. #64
    hello
    please post script for ford and honda nissan toyota odo calculation .thankx
  6. #65
    DK Veteran BeianM's Avatar
    Dorset UK
    Default hc908 upa usb script
    My most wanted script is for hc908 specific to the Renault Espace bcu & dash. One to change the km/mls in the bcu the other to reset the dash to zero. Can it be done?
    I have a tacho universal that does not want to work right now ( I seem to be drawn to chinese shit kit) & my Espace needs to go in for mot asap.
    Thanks in advance.
  7. #66
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by DrugWash View Post
    Wow!!!! So many writer of Remobjects Pascal here
    Thanks for the MMC script, all of you are great!!!!
    But I think it will be better if we calculate also the checksum
    I experience this in EVO 10 when CRC is wrong, it doesn't want to run the odometer mileage, but the trip and the neddles are working good
    Attach is the edited script, I dont touch any instructions from the orig script just added the chksum calculation and error message, to respect the original author
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  8. The Following 15 Users Say Thank You to hcip For This Useful Post:
    autosoftbrasil (19th November, 2021), BimmerGT1 (28th June, 2013), BlacksunLE (7th April, 2017), caprariu (9th February, 2023), davidjmj (9th April, 2015), digikeys (30th December, 2016), gameiruz (8th January, 2014), hbalazs (30th August, 2020), Jashmine1983 (6th December, 2014), karzan1977 (18th December, 2019), LEANDRO SANDES TEIXEIRA (26th June, 2016), marikette (24th December, 2023), ouragh (11th February, 2018), pintobraz (29th July, 2014), spower (4th June, 2013)
  9. #67
    Quote Originally Posted by hcip View Post
    Thanks a lot for correction. I have updated some scripts and added some images. Please look at it.
    BTW: hcip if you wish you can modify my scripts. If it possible please add the function for writing millage
  10. The Following 6 Users Say Thank You to DrugWash For This Useful Post:
    Dalautos (11th July, 2020), gameiruz (14th December, 2014), Krittanu (1st August, 2016), LEANDRO SANDES TEIXEIRA (26th June, 2016), mariusz971 (7th August, 2013), pintobraz (29th July, 2014)
  11. #68
    I'm need UPA script for read MCU (MC9S12DG128) Body Computer FIAT New Panda....THANKS
  12. #69
    italy
    Default utilizzo?
    come si usano gli script?
    cosa bisogna fare per attivarli?
  13. #70
    Hollywood
    OriginallyBody Computer FIAT
  14. #71
    Hollywood
    đđĐđß$đĐßđßđßđđääđłldkf>>;*;ßßߤߤ;>>;>ßߤ]$ß$÷÷×ßß]¤¤¤]ß$$[ß[¤ĐĐß[ß...
  15. #72
    hcip's Avatar
    Quote Originally Posted by schmizer View Post
    hello
    you can make your own script than to ask members who have ready to use script,
    There is a lot of examples here, just an imagination and a simple calculation and you will be learn little by little, the others will not grab your knowledge from you
    as for example below, the instruction is for Toyota denso
    just to improve it and you can make it with your own
    /// ****************** Denso Code *************** //
    procedure NewKM;
    var
    n3,n2,new_KM: integer;
    n1,code,n4: String;
    begin
    SetProgramModifiedOnly( true );
    if InBox( 'Enter KM', 'New KM',code ) then begin
    if length( code ) >6 then begin
    if MsgBox( 'Out of Range', 'Error', MB_RETRYCANCEL ) = IDRETRY then begin
    NewKM;
    end;
    exit;
    end;
    /// *******CALCULATION ************** //
    new_km:= (strtoint(code)+1000000);
    n1 := '$' +inttostr(new_KM);
    n2 := strtoint(n1);
    n3 := $FFFFFFF - (n2);
    n4 := inttohex(n3,2);
    // ******* END of CALCULATION *********//
    //********* OFFSETS *********///
    SetByteHexEdit( $A,(strtoint ('$'+n4[2]+n4[3])));
    SetByteHexEdit( $9,(strtoint ('$'+n4[4]+n4[5])));
    SetByteHexEdit( $8,(strtoint ('$'+n4[6]+n4[7])));
    end;
  16. The Following 5 Users Say Thank You to hcip For This Useful Post:
    AdrianCR (8th December, 2020), gameiruz (8th January, 2014), Paing Paing (20th November, 2018), pintobraz (29th July, 2014), Tariel (1st June, 2016)
  17. #73
    Top Poster boratokm's Avatar
    Monterrey Mexico
    Default tanks HCIP
    im test and work 100 %
  18. #74
    please post ford 9s12 script for focus,fiesta and fusion
    thankx
  19. #75
    hcip's Avatar
    thankx
    I have no Idea about scripting ford algo , because of hard checksum calculation
    but I think the example below will show how does it
    if there is another way of calculating crc, please post
    I will try another way to write the code in another day, I am too busy now
  20. The Following 5 Users Say Thank You to hcip For This Useful Post:
    antonypaul (17th February, 2014), BBDOPAI (24th March, 2019), BimmerGT1 (28th June, 2013), pintobraz (29th July, 2014), Tariel (1st June, 2016)
