hello mates,
i have upa-usb and want to read
MC9S12H256, MC68HC912D60
on vw beetle can someone help with the pinout diagram.
PC.
hello mates,
PC.
Try this.BR
Joseph "Proposition Joe" Stewart
antonypaul (1st March, 2015), choro (24th February, 2015), eleeinidis (9th May, 2017), Hayssam1 (31st July, 2018), jhonbernal1989 (20th April, 2020), mohamedkey (31st August, 2015), philipcoin (26th December, 2014), SergeyIg (15th November, 2015)
hello m8,
i need help on jaguar x-type cluster need pin out diagram
MC68HC912DG128,i have UPA.
thank you.
merry xmas.
PC.
Hi, could anybody help me to convert hexadecimal values onto Octal? with this UPA script I can display the code from radio in hexadecimal readed directly from eeprom or from saved dump. The algorithm is HEX>OCT/2, in this example is HEX(2A54)>OCT(25124)/2=12452. Thanks in advance.
Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
amir jafari (23rd May, 2017)
I can't find any new update, last update:
UPA-USB Device Programmer v1.3.0.14 r2 06-May-13
uuprog v1.3.0.14 revision 2
- Fixed "the code is not signed" error
- New USB driver upausb.sys. This driver is digitally signed and can be used with USB2.0/3.0 ports under 32/64-bit Windows XP/Vista/7/8
this update is for uuprog-s, not UPA-USB
Min2xx (14th March, 2016)
Ford/Nissan visteon algo solved. Script tested on Nissan Qashqai with 9s12xhz256, work perfect! Please push thanks button!![]()
antonypaul (1st March, 2015), aqemqum10 (7th January, 2021), AVDIMON (26th March, 2016), BBDOPAI (21st June, 2021), brchip (24th February, 2015), caprariu (11th February, 2023), cjawahir (18th December, 2016), csen06 (11th February, 2018), datapage (9th January, 2016), electronicdeivi (30th December, 2016), eleeinidis (9th May, 2017), erickson1212 (17th December, 2020), goran81 (31st October, 2020), hmagga (21st June, 2019), hoangtu (28th February, 2015), ivica21 (16th February, 2025), Jardel (25th December, 2021), joejam (6th June, 2022), kckite (4th December, 2015), KFZ (28th February, 2015), kin51 (23rd May, 2019), Krittanu (1st August, 2016), lexuscar (27th May, 2017), lupu_sandu (8th September, 2015), martinracing (19th March, 2015), maybach_ (23rd February, 2015), mimodiag (25th April, 2015), mohamedkey (27th September, 2015), MYMN (18th December, 2021), nesmark (2nd September, 2016), Nicolas8161 (29th November, 2024), Noetzel (15th July, 2015), PETERALC506 (1st August, 2015), saysso (26th May, 2017), SergeyIg (26th March, 2018), szogun0 (1st March, 2015), Tariel (9th November, 2015), TERNOCOD (14th June, 2015), trakilacee (20th June, 2016), winaiservice (16th May, 2017), zar0079 (29th October, 2021)
script not crypted, edit device group, or add new. these is script for add new device group and subgroup. Add new script for dashes VDO!
antonypaul (6th June, 2015), audiotek (26th September, 2019), BBDOPAI (21st June, 2021), brchip (24th February, 2015), brodaty (9th January, 2016), caprariu (11th February, 2023), Charlieb1 (24th April, 2024), csen06 (11th February, 2018), datapage (6th August, 2015), duckstar (5th May, 2020), hbalazs (30th August, 2020), hmagga (21st June, 2019), ivica21 (16th February, 2025), joejam (6th June, 2022), marrijonas (26th April, 2016), martinracing (19th March, 2015), maruti (2nd February, 2020), mendox (16th October, 2015), mohamedkey (27th September, 2015), otojm (31st August, 2015), ouragh (12th February, 2018), panqero (13th September, 2015), satesquio (28th November, 2015), Satmanek (24th June, 2020), skybroi (11th December, 2022), superchaveiro (11th September, 2018), szogun0 (31st August, 2015), TERNOCOD (14th June, 2015), valdirld (13th August, 2015), zyjekrc51 (7th October, 2016)
thanks you
New update for UPA:
uuprog-s v1.1.4.02 08-Sep-15
- Added support for Renesas V850 MCUs: uPD70F3333, uPD70F3334, uPD70F3335, uPD70F3336, uPD70F3340, uPD70F3341, uPD70F3342, uPD70F3343, uPD70F3350, uPD70F3351, uPD70F3352, uPD70F3353, uPD70F3370A, uPD70F3371, uPD70F3372, uPD70F3373, uPD70F3374, uPD70F3375, uPD70F3376A, uPD70F3377A, uPD70F3378, uPD70F3379, uPD70F3380, uPD70F3381, uPD70F3382, uPD70F3383, uPD70F3384, uPD70F3385, uPD70F3624, uPD70F3628, uPD70F3629, uPD70F3632, uPD70F3633, uPD70F3634, uPD70F3635, uPD70F3736
- Added support for Microchip eeproms 25LC512, 25LC1024
- Fixed some bugs
bluedid (12th September, 2015), electronistul21 (7th February, 2020), lidons (8th September, 2015), Locksmith Hungary (9th September, 2015), mohamedkey (16th November, 2015), soxten (12th November, 2015)
my upa dont work on windows 7
only god can judge me
drpeter,
How can I open and edit a file .uds. With software I need to use?
.................................................. .special case here , me thinks he needs headgear for the next time he bounce his head ,,,
Script for VAG ECU - ME7 and EDC16. Test and report. ecu.zip
angmar (4th December, 2021), brodaty (9th January, 2016), datapage (9th January, 2016), eliet2000 (4th June, 2023), hbalazs (30th August, 2020), hmagga (21st June, 2019), joejam (6th June, 2022), Krittanu (1st August, 2016), martinracing (29th October, 2017), mohamedkey (29th September, 2016), mossa19 (8th September, 2018), remhonda (14th January, 2016), satesquio (28th September, 2016), winaiservice (7th July, 2016), yahia1908 (25th March, 2020), zyjekrc51 (7th October, 2016)
