Page 6 of 88 FirstFirst 12345678910111656 ... LastLast
Results 76 to 90 of 1311
  1. #76
    Top Poster boratokm's Avatar
    Monterrey Mexico
    Default Example Modify Hours of Ford F350 Disel 2004-2006
    regards
    octavio
  2. #77
    Thanks a lot. Is it possible to attach the script as attachment?
  3. #78
    Monterrey Mexico
    Default I need Script for Nissan Xtrail
    i need one example for Algo of Nissan Xtrail 93C66 tanks all programmers regards
    octavio
  4. #79
    Monterrey Mexico
    Default Begin Script Nissan Xtrail
    hehehe we need algo for line 70 regards
    Program Prog;
  5. #80
    Monterrey Mexico
    Program Prog;
    procedure NewKM;
    var data: integer;
    a: integer;
    begin
    if not ReadDevice then begin
  6. #81
    As I can see we also need to calculate the line 60
    0060: xx xx xx xx xx xx xx xx D7 B4 AF 69 5E D3 BD A6
    0070: xx xx AD 69 5A D3 xx xx xx xx xx xx xx xx xx xx
    where the next bytes:
    String #1 = D7 B4 AF 69 5E D3 BD A6
    String #2 = AD 69 5A D3
  7. #82
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    just put 0000 on line 60 and calculate line 70, its the other way of calculation like diga
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  8. The Following User Says Thank You to hcip For This Useful Post:
    hp7909 (15th February, 2018)
  9. #83
    Guys please try this formula for Xtrail:
    2070869724 - round(NewKM/54)*33555456 and after that to convert to HEX
  10. #84
    hcip's Avatar
    Try this if will work
    Haven't test it yet in actual Meter
    Program Prog1;
    var
    Code_1 : string;
    KMa: Integer;
    Procedure ReadKM1;
    begin
    MsgBox( 'Read Error', 'Error', MB_OK );
    end;
    VerifyDevice;
    begin
    AddMsg('Reading EEPROM');
    Code_1:=inttohex(GetByteHexEdit($69),2)+inttohex(G etByteHexEdit($68),2) ;
    KMa :=(($FFFF - strtoint('$'+Code_1))-18626) *53;
    AddMsg('Actual value' + ' = '+ IntToStr(KMa)+' km');
    MsgBox (inttostr(KMa) +' km', 'Actual value', MB_OK);
    exit;
    end;
    end;
    procedure NewKM;
    var
    n2,n5,n8,nb,new_KM,km,km1,km2,km3: integer;
    n1,n3,n4,n6,n7,n9,na,nc,code: String;
    begin
    SetProgramModifiedOnly(true);
    if InBox( 'Enter KM', 'New KM',code ) then begin
    if length( code ) >6 then begin
    if MsgBox( 'Out of Range', 'Error', MB_RETRYCANCEL ) = IDRETRY then begin
    NewKM;
    end;
    exit;
    end;
    km:= (strtoint(code) /53)+18626;
    n1 := inttostr(km);
    n2 := $FFFF -strtoint(n1);
    n3 := inttohex(n2,4);
    km1:=( (strtoint(code) /53) * 2 )+37252;
    n4 := inttostr(km1);
    n5 := $FFFF -strtoint(n4);
    n6 := inttohex(n5,4);
    km2:=( (strtoint(code) /53) * 4 )+8969;
    n7 := inttostr(km2);
    n8 := $FFFF -strtoint(n7);
    n9 := inttohex(n8,4);
    km3:=( (strtoint(code) /53) * 8 )+17938;
    na := inttostr(km3);
    nb := $FFFF -strtoint(na);
    nc := inttohex(nb,4);
    SetByteHexEdit( $69,(strtoint ('$'+n3[1]+n3[2])));
    SetByteHexEdit( $68,(strtoint ('$'+n3[3]+n3[4])));
    SetByteHexEdit( $6B,(strtoint ('$'+n6[1]+n6[2])));
    SetByteHexEdit( $6A,(strtoint ('$'+n6[3]+n6[4])));
    SetByteHexEdit( $6D,(strtoint ('$'+n9[1]+n9[2])));
    SetByteHexEdit( $6C,(strtoint ('$'+n9[3]+n9[4])));
    SetByteHexEdit( $6F,(strtoint ('$'+nc[1]+nc[2])));
    SetByteHexEdit( $6E,(strtoint ('$'+nc[3]+nc[4])));
    SetByteHexEdit( $73,(strtoint ('$'+n6[1]+n6[2])));
    SetByteHexEdit( $72,(strtoint ('$'+n6[3]+n6[4])));
    SetByteHexEdit( $75,(strtoint ('$'+n9[1]+n9[2])));
    SetByteHexEdit( $74,(strtoint ('$'+n9[3]+n9[4])));
    end;
    RefreshHexEdit;
    if MsgBox( 'Program?', 'Confirm', MB_YESNO ) = IDYES then begin
    ProgramDevice;
    VerifyDevice;
    ReadKM1;
    end;
    end;
    begin
    /// ***** Menu 93C56 **** ///
    AddDeviceGroup( 'Dash NISSAN', 'Mileage' );
    AddDevice('-=Nissan Xtrail C56=-', '93C56', 'Dash NISSAN', '93C56 x16' );
    AddAction( 'Read KM', 'ReadKM1', '-=Nissan Xtrail C56=-' );
    AddAction( 'New KM', 'NewKM', '-=Nissan Xtrail C56=-' );
    /// ******** Menu 93C66 ******* ///
    AddDevice('-=Nissan Xtrail C66=-', '93C56', 'Dash NISSAN', '93C66 x16' );
    AddAction( 'Read KM', 'ReadKM1', '-=Nissan Xtrail C66=-' );
    AddAction( 'New KM', 'NewKM', '-=Nissan Xtrail C66=-' );
    end.
  11. The Following 2 Users Say Thank You to hcip For This Useful Post:
    gameiruz (15th December, 2014), Tariel (1st June, 2016)
  12. #85
    Monterrey Mexico
    Default HCIP Many Tanks im test
    i test now nissan and say what happen
  13. #86
    Monterrey Mexico
    Default Test Finish
    HCIP tanks for all your help
  14. #87
    hcip's Avatar
    Good to hear from you
    here is another script for toyota
  15. The Following User Says Thank You to hcip For This Useful Post:
    jevgensolo (29th May, 2013)
  16. #88
    tehnosoftex's Avatar
    Romania
    Mercedes Sprinter, Vito, a class b class with borg dash 95640 memory script
  17. The Following 18 Users Say Thank You to tehnosoftex For This Useful Post:
    AMDOR (11th August, 2019), BBDOPAI (24th March, 2019), BlacksunLE (7th April, 2017), caprariu (9th February, 2023), ciptel07 (25th December, 2013), digikeys (30th December, 2016), eleeinidis (9th May, 2017), hbalazs (30th August, 2020), johnybilly (26th December, 2013), karzan1977 (18th December, 2019), LEANDRO SANDES TEIXEIRA (26th June, 2016), mariusz971 (7th August, 2013), ouragh (11th February, 2018), Oxidoferroso (31st July, 2023), pintobraz (29th July, 2014), reglissebudy (19th February, 2017), satesquio (28th November, 2015), sergei5005 (3rd June, 2015)
  18. #89
    hcip's Avatar
    Hi members
    I am not really familiar with the Pascal language
    can I ask these queston?
    How to convert the decimal number in Octal number?
    Also How to execute the loop command for Pascal?
    I cannot execute it using:
    For x := y to z do (or downto)
  19. #90
    Quote Originally Posted by hcip View Post
    Hi members
    Hello. Please look at my script.
  20. The Following 4 Users Say Thank You to DrugWash For This Useful Post:
    gameiruz (5th December, 2014), LEANDRO SANDES TEIXEIRA (26th June, 2016), ouragh (11th February, 2018), pintobraz (29th July, 2014)
