I would like to attach the crc16 script for everyone, but I don't think attachments function.
hehehehehe :
hehehehehe :
HiAttachment function.
Or you can save it on mega or Google drive.
lgmchaveiro (21st August, 2021)
here is your attached script
it must be rared
Its from icmchaveiro
I don't know if it working correctly though. It says compute checksum. What is it supposed to do?
lgmchaveiro (21st August, 2021), ProblemChild (24th December, 2023), Team dz (28th September, 2022)
Hi guys, has someone managed to make a script for Eeprom CRC correction in M/EDC17 ecus?
I will also pay if someone has a working script..
Olá amigo, posso fazer isso sim. mas é muito complicado que terei que fazer para você copiar o bloco 1 a 1 aberto no script e fazer com que ele ajuste o crc. para fazer todo o ecu carecem de alguns algoritmos. Procuro muitos algoritmos para fazer edc17 med17 vw immo data, porque emm brazil eu tenho outros ecus que ferramentas de nível mundial não fazem.
I'm currently working on a script for the mareli nec +95320 cluster
systems g6 g7 brazil up beatee jeeta, odometer in km immo data and rfid keys
Jonatanfunes91 (25th July, 2022), Nostalgic85 (1st November, 2022)
you should know the block of your file select, copy and paste in the crc16 editor, then compute crc it calculates checksum and will give you several results of crc 16 . if you know what type of crc16 uses your dump blocks you will understand the crc function.
this crc are all correct i used for base creation crc 16 online.
https://crccalc.com/
Antonio266 (22nd August, 2021), antonypaul (6th February, 2023), chcp (22nd August, 2021), fuzz1 (22nd August, 2021), MOBILTRONIC (24th October, 2021), ProblemChild (24th December, 2023), Willinickersen (22nd August, 2021)
Just wondering if anyone has been able to read any mcu not listed officially with UPA-USB.
What chip have anyone tried and been successful (not officially listed as possible to be read by usb-upa)?
Hello Every 'one'
Can Some one tell how to save file into Bin type in this sample script?
procedure Button4Click(Sender: TObject);
var e: TXHexEdit
begin
e := GetHexEdit();
if e <> nil then
if SaveDialog1.Execute(' ') then
e.SaveFile( SaveDialog1.FileName );
end;
A BIG thanks for help.
Paing Paing (27th December, 2021)
[QUOTE = cartagena; 4210529] Olá a todos 'um'
Alguém pode dizer como salvar o arquivo no tipo Bin neste script de exemplo?
procedimento Button4Click (Sender: TObject);
var e: TXHexEdit
begin
e: = GetHexEdit ();
se e <> nulo então
se SaveDialog1.Execute ('') então
e.SaveFile (SaveDialog1.FileName);
fim;
Um MUITO obrigado pela ajuda. [/ CITAR]
You can use SaveDialog Filter & filter index in code to show multiple selection of file
eg:
SaveDialog1.Filter :='Any File [*.*]|*.*|Binary [bin file]|*.bin|Diga [*.e2p File]|*.E2P|Motorola [S19, S28, S37, mot]|*.S19;*.S28*.S37;*.mot;|Motorola [S19]|*.S19|Motorola [S28]|*.S28|Motorola [S37]|*.S37|Motorola [PonyProg]|*.mot';
var e: TXHexEdit
begin
e := GetHexEdit();
if e <> nil then
end;
See attached picture
