Page 79 of 88 FirstFirst ... 29697475767778798081828384 ... LastLast
Results 1,171 to 1,185 of 1306
  1. #1171
    Jun 2013
    brasil
    hello friends, someone already managed to create a routine for checking and also adjust crc in med17 edc17 centrals, i know that it has 2 crc one 16 and one crc32, in some applications i can make crc16 and crc 16ccitt, i can exchange ideas on telegram 55 54 991062864 , it will be a great pleasure to share a little, but only in pm or telegram.
    I really like creating applications for RFID and also sincere for immo.
    sorry bad english
  2. #1172
    GMXcool's Avatar
    May 2009
    Delete from private message ! You cannot receive new messages !
    Quote Originally Posted by lgmchaveiro View Post
    sorry bad english
  3. The Following User Says Thank You to GMXcool For This Useful Post:
    lgmchaveiro (19th January, 2021)
  4. #1173
    Jun 2013
    brasil
    [QUOTE = GMXcool; 4042853] Olá,
    Excluir da mensagem privada! Você não pode receber novas mensagens! [/ QUOTE]
    I don't understand friend, what should I do
  5. #1174
    Jun 2013
    brasil
    Não entendo amigo, o que devo fazer
  6. #1175
    GMXcool's Avatar
    May 2009
    Your messages on this forum is full (check Inbox). You must delete messages in order to receive more !
    Suas mensagens neste fórum estão cheias (marque a caixa de entrada). Você deve excluir mensagens para receber mais !!!
  7. #1176
    Jun 2013
    brasil
    a small contribution to the friends of the forum
    fiat 500 eeprom 93c86X16 decript keys
    REQUIRES ONLY IN UPA S CURRENT VERSION
    test and report
    https://drive.google.com/file/d/1fiN...ew?usp=sharing
  8. The Following User Says Thank You to lgmchaveiro For This Useful Post:
    datapage (21st April, 2021)
  9. #1177
    Mar 2018
    Someone have script for grande punto bcm(93c86)pincode?
  10. #1178
    Jun 2013
    brasil
    hello and the same I sent free friend fiat 500 and gran punto to make rfid
    updated driver link. thank you please
  11. The Following User Says Thank You to lgmchaveiro For This Useful Post:
    fuzz1 (9th June, 2021)
  12. #1179
    Jun 2013
    brasil
    hello friends i'm bringing an image and a dump to see if anyone has already managed to create algorithms or know what type of crc uses this ecu in brazil goal 4lv polo 4mv and ec 4gv with the same type of dump
  13. The Following User Says Thank You to lgmchaveiro For This Useful Post:
    eliet2000 (4th June, 2023)
  14. #1180
    Jun 2013
    brasil
    i am not able to add a dump but ok image
  15. #1181
    Mar 2017
    can you give me an example?
    Thank you
  16. #1182
    Mar 2017
    hello friend gaston37 you have to create 2 editors in upa. and don't use normal reading editor.
    Thank you
  17. #1183
    Oct 2014
    Guys I'm trying to finish a script but I'm new to pascal, I need to find the address of the first instance of a string, searching from address $3FF0 and up (read from $3FF0 to $0000) then read the 4 bytes below that. For example if the string is found at $1010 then I need to read 4 bytes starting at $1020. There is more than one string but only the one closest to $3FFF is the correct one.
  18. #1184
    Oct 2014
    Figured it out...
  19. #1185
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by apexseal View Post
    Figured it out...
    Now you leave us wanting to know how you solved it. What was the solution
