UPA USB sample script wanted - Page 75
Page 75 of 75 FirstFirst ... 2565707172737475
Results 1,111 to 1,122 of 1122
  1. #1111
    reproteq's Avatar
    somewhere in this 13.700.000.000 years old universe
    155
    Downloads
    3
    Uploads
    Attachment 592509I am working in a full soft for upa
    here image of desktop
    when i finish i can share here.
    thanksAttachment 592508
    sorry i duplicate post for is error.
  2. The Following User Says Thank You to reproteq For This Useful Post:
    rybenz (9th April, 2019)
  3. #1112
    reproteq's Avatar
    155
    Downloads
    3
    Uploads
    Mi aportation code uds for immooff msa15 edc15v
    Program Prog1;
    ///////////vars/////////////////////
    var code_1,code_2,code_3,code_4,code_5,DataArray,DataR eaded: string;
    spstr1,spstr2, offstr1, offstr2, offstr3, offstr4, offstr5 : ansistring;
    ///////////////////////////// function ReadData //////////////////////////////
    Procedure ReadData;
    begin
    //////vars///////
    spstr1 := ' ';
    spstr2 := ' ';
    offstr1 := '0x53';
    offstr2 := '0x65';
    offstr3 := '0x67';
    offstr4 := '0x82';
    offstr5 := '0x96';
    if not ReadDevice then
    begin
    MsgBox( 'Read Error', 'Error', MB_OK );
    end
    else begin
    DataArray:= offstr1 + spstr1 + inttohex(GetByteHexEdit($53),2)+ spstr2 +
    offstr2 + spstr1 + inttohex(GetByteHexEdit($65),2)+ spstr2 +
    offstr3 + spstr1 + inttohex(GetByteHexEdit($67),2)+ spstr2 +
    offstr4 + spstr1 + inttohex(GetByteHexEdit($82),2)+ spstr2 +
    offstr5 + spstr1 + inttohex(GetByteHexEdit($96),2);
    MsgBox( DataArray, 'DataReaded', MB_OK or MB_ICONINFORMATION );
    //AddSaveFileAction( 'SAVEFILEREAD', 'IMMO_VAG_MSA15-EDC15', 'C:\Users\w7\Desktop\ReadFile_IMMO_VAG_MSA15-EDC15.bin' );
    end;
    end;
    ///////////////////////////function IMMOOFF ///////////////////////////////
    procedure ImmoOFF;
    //////vars///////
    var data1,data2,data3,data4,data5,value1,value2,value3 ,value4,value5 : integer;
    begin ////////////////////////readerror ////////////////////////
    if not ReadDevice then begin
    end
    else begin ////////////////////////setmodify ////////////////////////
    SetProgramModifiedOnly( true );
    if MsgBox( 'Erase Immo Data?', 'Confirm', MB_YESNO ) = IDYES then begin
    ///set value1 ////
    data1 := $53;
    value1 := $60;
    SetByteHexEdit(data1 , value1);
    ///set value2 ////
    data2 := $65;
    value2 := $60;
    SetByteHexEdit(data2 , value2);
    ///set value3 ////
    data3 := $67;
    value3 := $60;
    SetByteHexEdit(data3 , value3);
    ///set value4 ////
    data4 := $82;
    value4 := $60;
    SetByteHexEdit(data4 , value4);
    ///set value5 ////
    data5 := $96;
    value5 := $60;
    SetByteHexEdit(data5, value5);
    RefreshHexEdit;
    end;
    end;
    end;
    begin
    AddDeviceGroup( '_REPROTEQ:SCRIPT_', 'SELECT DEVICE CAR' );
    AddDevice( 'IMMO_VAG_MSA15-EDC15', '24C02 ', '_REPROTEQ:SCRIPT_', '24C02');
    AddAction( 'Read_Data', 'ReadData', 'IMMO_VAG_MSA15-EDC15' );
    AddAction( 'Immo_OFF', 'ImmoOFF', 'IMMO_VAG_MSA15-EDC15' );
    // AddOpenFileAction( 'BOX Top Side', 'IMMO_VAG_MSA15-EDC15', 'VW2.jpg' );
    //AddOpenFileAction( 'PCBoard Top Side', 'IMMO_VAG_MSA15-EDC15', 'VW1.jpg' );
    //AddOpenFileAction( 'Connections', 'IMMO_VAG_MSA15-EDC15', 'VW3.jpg' );
    AddMsg('Script (REPROTEQ_IMMO_VAG_MSA15-EDC15.uds) Installed OK! Reproteq'#169'');
    SetProductInfo( 'REPROTEQ_IMMO_VAG_MSA15-EDC15', 'Script'#$D' Reproteq '#169'');
    end.
  4. The Following User Says Thank You to reproteq For This Useful Post:
    PaoloDigital (19th March, 2019)
  5. #1113
    Nov 2012
    99
    Downloads
    16
    Uploads
    I wanted script for benz dash w212 2013-, w205, w447. I will pay.
  6. #1114
    mikroel's Avatar
    Jan 2010
    EU
    150
    Downloads
    99
    Uploads
    do you have VW2.jpag,VW1.jpg,VW3.jpg also?
    also other part of script with screen ?
    Marelli decoder
    ,Carprog FULL + NEW 4in1 adapter ,Orange5 calcs,UUPA PRO Adapters,KESS,KTAG
  7. #1115
    reproteq's Avatar
    155
    Downloads
    3
    Uploads
    this code is commented because not use this images.
    but if you want can uncomment and add images of ecu and eeprom.
    this is a simple script
  8. #1116
    mikroel's Avatar
    Jan 2010
    EU
    150
    Downloads
    99
    Uploads
    Yes i see that but ,
    You have few mistakes in this script
    Marelli decoder
  9. #1117
    Member hectorcairo's Avatar
    Aug 2011
    8
    Downloads
    50
    Uploads
    Hello good day, maybe a script that goes well, for Body FIAT 326?
    regards
  10. #1118
    Apr 2019
    7
    Downloads
    88
    Uploads
    Hello all friends...
    Does anybody can make immo off script for denso, fujitsu, mitsubishi Ecu please?.
    Thank you.
  11. #1119
    Top Poster + turbocip's Avatar
    22
    Downloads
    144
    Uploads
    Can i use this scripts at this thread with UPA UUSP?
    Thanks in advance
  12. #1120
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    120
    Downloads
    56
    Uploads
    Hello.
    I read an ecu iaw 5nf,(eeprom on board) but when writing, a part of the memory Is not write, I managed to write in this area after many attempts, eeprom is not from the ecu it is one st95160, the programmer is written normally the chip.... But upa doesn't, do you know something about it?
  13. #1121
    Oct 2018
    4
    Downloads
    Uploads
    hello i need a script for dash of FIAT SCUDO 2014 with 95020 eprom.
  14. #1122
    Mar 2019
    east europe
    24
    Downloads
    Uploads
    Hy.can somone help with calculator hex for full Ford kuga 2011 mcu 9s12xh256 because i can read but in my carprog no calculator for this mcu .thank
