Results 1 to 15 of 22
    Default USB-RS232 Cable Driver
    I've bought a USB to serial port converter but i can't work with it.
    Unfortunately the driver CD provided with the converter doesn't work. So I need that driver badly. I searched a long time to find that driver but my attempt was fruitless. I got some drivers but none of them worked for me. Please any one help me.
    Feb 2009
    are you sure its strange if the driver that came with it does not work,have you made sure the same com ports are in use,ie com 1 on pc in device manager,,and com 1 in other loader or whatever your using. have you tried a windows update sometimes it finds a more updated one,especially if the original was for xp and your using win 7 .
    pawliukazz's Avatar
    Jupiter
    Have you tryed DriverGenius? Maybe this tool can find you required drivers...
    DK Veteran johnboy1974's Avatar
    glasgow
    have you tried plugging it into your computer it might download drivers for it automatically it did with mine.
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by johnboy1974 View Post
    i think it downloads only if you purchase your Windows
    I have one and my one dont work too,
    V.I.P. Member steppenwolf's Avatar
    Mar 2009
    Serbia
    Post
    Try to download from here. It`s in the automotive section.
    http://www.digital-kaos.co.uk/forums...-elm327-83308/
    Try download from here
    FTDI Drivers
    bram380's Avatar
    Indonesia +628153111774
    Default USB Driver
    USB driver:
    PL-2303
    PL-2302
    HL-340 Device
    FTDI-232
    Mar 2011
    for prolific drivers you can also go to their website:
    http://www.prolific.com.tw/eng/downloads.asp?id=31
    hi there
    comes up page error mate
    DK Veteran KenshinPT's Avatar
    PT
    Sorry for this thread hijack but I am in trouble.
    I bought an ExpressCard 34mm to get a serial port in my laptop.
    However, later I found out that the ExpressCard can be connected into the PCMCIA 34mm socket via PCI or USB... and that's why I am in trouble... this ExpressCard is in fact a USB to RS232 converter and not a true RS232 port.
    I always knew that USB<->RS232 converters work very slowly with certain devices.
    Yesterday I tested this converter with some RS232 hardware I own and the data transmission is very very... very slow...
    My question here is simple: This converter is based in the prolific chip, so, and does anyone knows how to get this work faster?
    Did it help? Push Thanks below
  13. #13
    Apr 2011
    But with this device programmators may be working not correct!!! It no have time sinhronization with falling or rising levels of signals...
  14. #14
    Mar 2011
    DriverGuide
    This is usually where I go first to search for drivers. As long as you know the make/model of the device, you can usually find a driver for it there.
  15. #15
    Dec 2011
    Ok, lets see if it works.
