I used this opcom on my corsa 2006, now I have an astra, but when I plug it in and select to automatically find my car it says no communication with ECM
anyone know why please?
does it communicate if you manually select model, year & engine type? must admitt i've always gone for manual selection & had no problems with communication
Are you selecting "KWP-2000" or "CAN" ??
you shud be selecting "CAN" mate
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
Some of the copy interfaces have issues with CAN. You should be able to hear relays clicking inside, as previous poster says, your new vehicle is CAN, your old one wasn't. Maybe that is the clue.
thanks everyone for your help, what I found out was that this software some how doesnt work on my new car, so I searched the forum and found this person who uploaded various versions of the software, tried a few untill one of them worked without needing the verification code, so its working spot on, for those of you who own a astra H or MK5 and fited HID kit you will find they display a warning signal or the lights strobe when engine is on, with OP-COM you can use it to program the lights to accept the HID kit therefore you dont need to buy CANBUS kit which is over 100 pounds,
anyway, now for part two of help I need, Im trying to get into the ECU for millage correction etc etc but it asks me for a 4 digit password, can anyone help me find this password? or has a software that fully works which I can use with my interface? thanks![]()
i dont think you can correct the miles in the ecu mate
especially not with op-com
I've heard you can do it with the OP-COM as I know someone who has done it with OP-COM before, but they wont tell me how, I can do it with my OP-COM I just need the 4 digit password if anyone can help?? also, for vauxhalls, whats a common millage correction interface?
YOU CANT DO MILEAGE CORRECTION IN THE ECU MATE
damn caps
dont ask questions if your not gonna pay any attention 2 them, that way people wont waste their time helpin you
well can you help me find a 100% fully cracked software that doesnt ask for the password!!!! and even better reccomend me a good/cheap millage corection kit plz
the password is on the car pass (same as your radio code) but as z786 said opcom won't help. I don't do that sort of thing anyway so cannot be of any further assistance
cheers mate thats all I needed to know now Im going to try that as I have the security code pass appreciate your help
thanks mate, is it pretty straight forward?
should be mate
and if you wanna thank a person, you press the red thanx button on the bottom of their post, it saves useless posts
In regards to this tool you recommended... Opel EDC16...
It says on the description that for some cars changes in dash too... Description is kind of confusing for me so I am not quite sure for which models is able to change in ecu and dash together... Is that for the models where it says read/write KM....
Thanks in advance...
Here is the info from site you recommended...
The software together with interface is designed for changing the state of kilometers in engine controllers EDC16 in OPEL cars. Everything takes place through diagnostic plug. The software is enriched in the possibility of changing dashboard in selected models. Set contains interface in professional plug OBD which is at the same time the key for activating the program, original CD with program and controllers.
Support:
EDC16 1.7 CDTi
EDC16 1.9 CDTi
EDC16 2.0 CDTi
Agilla read/write KM
Corsa C read/write KM
Astra ....2000 read/write KM
Astra 2000.... read/write KM
Vectra ....98 read/write KM
Vectra 98.... read/write KM
Opel Bosch ME7.6.2 ECU's : read/write KM
TIGRA BZ14XEP 2005 - 2009
ASTRA HZ14XEP 2004 - 2009
Z12XEP 2006 - 2009
Z14XEL 2004 - 2009
Z20LER 2005 - 2009
Z20LEL 2004 - 2009
Z20LEH 2005 - 2009
Z16LET 2007 - 2009
CORSA DZ14XEP 2007 - 2009
Z12XEP 2007 - 2009
Z10XEP 2007 - 2009
Z16LER 2007 - 2009
ZAFIRA B Z20LER 2005 - 2008
Z20LEH 2006 - 2009
