Results 1 to 13 of 13
    Member mic_mic's Avatar
    Apr 2008
    Default Cant find tuxbox??? help please
    Im using a 600c flashed with mr.dudes noob image, and since there does'nt seem to be a permanent fix for our loss of channels I thought I would try a manual key input as i want to watch the toon v pompey tomorrow. Problem is i cant find tuxbox commander, in the plugins menu it has the options;
    Dreambox image back up
    cam keys
    services & bouqets
    preapre for flashing
    Anyone help?
    If i need to flash a new image to my box to get tuxbox which one is best?
    thanx
    Administrator
    Devilfish's Avatar
    Feb 2008
    Unfortunately not all images have the tuxbox commander plugin installed. It's at the descretion of the image creators what they include.
    I believe the CLi image for the DM600 has a version included.
    Apr 2008
    Quote Originally Posted by Kaos View Post
    Where would i get a good CLi one from mate?
    V.I.P. Member Jaffa's Avatar
    Mar 2008
    Norn Iron
    Quote Originally Posted by mic_mic View Post
    There one in the downloads section, which will be available to you after 5 posts.
    Apr 2008
    Come on the 5 time is running out!!
    sure i tried a CLi image before i used the noob one and I could'nt get any other image to work when i first got the box.
    can i not flash the plugin to my box and leave the current image on it for the time being? as im assuming i will have to flash a new image on when the new fix comes.
    Apr 2008
    Quote Originally Posted by Jaffa View Post
    They all say Pli is that the same as CLi as there is none of the latter
    Administrator
    Devilfish's Avatar
    Feb 2008
    PLi and CLi images are not the same.
    Flashing is only done with a complete image. If you want to transfer individual files you need to connect the dreambox to your PC using a crossover ethernet cable and use an ftp program.
    Apr 2008
    well no i will flash the cli image onto it but i cant find it. is it in the 600 download section?
    V.I.P. Member father ted's Avatar
    Feb 2008
    scotland
    why dont you manually add tuxbox to your plugins via ftp method?am sure in downloads there is one ,just connect via flash fxp,and find your plugins add file to chmod to 755 and reboot
    Apr 2008
    have'nt got the cable to do that mate, thats why i need to re-flash a good image onto it
    Administrator
    Devilfish's Avatar
    Feb 2008
    I've uploaded the CLi image here...
    http://www.digital-kaos.co.uk/forums...do=file&id=111
    Apr 2008
    cheers mate
  13. #13
    Apr 2008
    do i do a channel scan in the usual way then go and change the keys as it says in the guide on here and that should be it
