Page 11 of 56 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 826
  1. #151
    Dec 2010
    also i clean egr sensor they was dirty you now carbo but now the rpm come down to 800 theywas 950
  2. #152
    makura's Avatar
    Default How you can use an expired incal cd
    well all you need is any incal cd go to my computer,explore the cd,open the file intelect,then open esdn,then open data,copy the folder you need and past it in C:/calterm it will ask if you want to overwrite the existing file click yes to all,now when you want to calibrate using calterm,you will have to choose the cal file from C:/calterm,go to the folder of the type of ecm you want to calibrate for example lets say select plus,you nevigate to the folder c94,open it and select the cal file you want.i have gone through all my celect plus cal files in calterm and renamed them,using CPL,HP,TORQUE and RPM/gorvnd speed.
    This makes it a whole lot easier to select a cal file if you don't know the ecm code by number.
    After you select your file you can now calibrate your ecm using calterm and files from an expired incal
  3. The Following User Says Thank You to makura For This Useful Post:
    busha (23rd November, 2016)
  4. #153
    DK Veteran hercamp's Avatar
    Talking egr
    Quote Originally Posted by je69 View Post
    hi everybody, about the isx egr and fan,yes hercamp i got new fuel fllter,diesel its new,iclean the valve and the litle electric motor its good, when you sain recalibrate you mine recabrate the valve with insite or recalibrate the ecm, thanks
    I mean...just the valve...make some test with insite..open that /close...and turn on/off ignition couple times...thats will change the position of egr ....or (autocalibration at start)
    the life is easy... people complicate!!!!!!!!
    life is funny just step away of people that wants make your life a shixx
    http://youtu.be/PEw3nYmpEys
  5. #154
    Dec 2010
    ok hercamp you se thats new to my i do that tomrrow, apreciate moch thanks sorry my english
  6. #155
    Top Poster + donniemnemonic's Avatar
    Nov 2010
    Hell's garden of eden.
    Quote Originally Posted by makura View Post
    Thanks for this makura.
    please post in Cummins incal solutions and tips thread where we are trying to compile all this useful information on incal so it is easier for everyone else to find.
  7. #156
    DK Veteran mondao's Avatar
    i want spik with the driver of the truck and see maibe the truck as a egr and fan troble o ready wend she blow the resistace and its 2 o 3 diferent problems i think i dont now figuratout
    can tell us how fix the problem,please
    If you intend to use this information to impress your friends, leave it
    and grow up!
  8. #157
    Member sptecnico82's Avatar
    Sep 2010
    Sonsonate, SV
    Talking ECM dont turn on
    Hi everybody.
    I have a celect ECM that just make a noise like a scream... I look in the past post and nothing work for me. I have just about 0.5 v in the big green capacitor.
    Any idea.
    Share and use the THANKS button and from time to time somebody will help.
    PD. Use the REPUTATION button too.
  9. #158
    Nov 2010
    Quote Originally Posted by sptecnico82 View Post
    Hi everybody.
    Any idea.
    Even when you are not getting around 102 volts on large green capacitor you should at least get 12 volts on it when the injector boost voltage circuitry is faulty. Are you getting 12 volts on the 2 legs of the silver diode when ecm has battery supplied and ignition turned on.The diode looks like a power transistor.
  10. #159
    Sep 2010
    Sonsonate, SV
    I will look for that.
    Thanks.
  11. #160
    Sep 2010
    Sonsonate, SV
    Unhappy
    Hi friends.
    I have a problem with a Celect+ ECM. I tried to recalibrate with insite, then calibration fault, after, I removed the ECM from the engine and connected it stand alone, I put the start switch for 5 seconds and it start in ROM mode. Afther, I start a new calibration, but always fails in 80%.
    Some idea? I have calterm, but I have no calibrations for the ECM.
  12. #161
    Nov 2010
    Hi friends.
    How did you calibrate it with insite if you have no calibration files for that ecm? And secondly why are you performing a recalibration? Also you did not give feedback on what you found with the celect ecm you were working on. The idea of these forums is to share problems and solutions. Feedback please, its important for others following the thread to know whats happening.
  13. #162
    Sep 2010
    Sonsonate, SV
    OK. I was no more working with the celect, them I dont have any feedback yet. I calibrate the celect plus with incal cd.
  14. #163
    Nov 2010
    had also asked you why you wanted to recalibrate the ecm? is it to change engine parameters or does the ecm have a fault requiring recalibration? e.g footprinted or seeded?
  15. #164
    Sep 2010
    Sonsonate, SV
    The ecm was from a M11 and need to be used in a N14, many parameters dont work properly.
  16. #165
    makura's Avatar
    Copy cal files from your incal dvd to incal,read my post above.people if you take time to read other people's post's you would'nt be asking questions that have been answered already,and to make maters worse it's on the same page as your post.we are wasting time and space on the same issues here,PLEASE READ NEW POSTS AND USE SEARCH FACILITY HERE.
