Page 44 of 56 FirstFirst ... 34394041424344454647484954 ... LastLast
Results 646 to 660 of 830
  1. #646
    Feb 2013
    brasil
    Please precise insit + 6.7 kg
  2. #647
    Oct 2010
    I have a celect plus ecm that will not take a cal, even after rom boot with a bench harness. I noticed that the bootloader version box is blank in Calterm when I am connected to it. Is the bootloader available as a file, and can it be reloaded into the ecm?
    Thanks!
    HP
  3. #648
    Top Poster + donniemnemonic's Avatar
    Nov 2010
    Hell's garden of eden.
    Quote Originally Posted by hpcummins View Post
    Thanks!
    HP
    Hi m8
    Have you tried unlocking the module? That sometimes helps.
    Donniemnemonic
  4. #649
    Nov 2010
    Quote Originally Posted by amosquedat View Post
    I have a Celect ECM, shows me all injectors at fault and when I try to turn it shows me all the sensors fails, where I can begin to repair
    Thanks to all
    Hi m8
    What fault codes are you getting from ECM? Be specific this can help in your troubleshoot.
    Donniemnemonic
  5. #650
    Oct 2010
    Quote Originally Posted by donniemnemonic View Post
    Hi m8
    Donniemnemonic
    Thanks,
    Will try that tomorrow and let you know.
    HP
  6. #651
    Nov 2010
    Thanks,
    HP
    Hi m8
    Good luck! will try to help as best as I can. Do let me know how it goes.
    Donniemnemonic
  7. #652
    Oct 2010
    Hi m8
    Donniemnemonic
    Donniemnemonic,
    I used calterm unlock, found status was 1DOA. I changed it to 5EED, then to 600D, turned the ignition off for 30 seconds, then back on and much to my amazement run location is now default and the original cal file and parameters are back!
    Thanks!
    HP
  8. The Following User Says Thank You to hpcummins For This Useful Post:
    BUSCADOS (2nd November, 2023)
  9. #653
    Nov 2010
    Donniemnemonic,
    Thanks!
    HP
    Hi Hpcummins
    Glad you got it working again, though I can't take credit for that you figured that one all on your own. Seems the more we play around with calterm the more we seem to learn.
    Did not even realise that it was possible to revert to default and regain full operational functionality from Romboot without having to recalibrate. Nice share m8.
    Do you know if there are any E2m files for celect ecms besides the ones posted here by Jctech cause all the ones here do not display the correct ecm part and serial numbers. Unlike the celect plus ecms and so I am not sure of the accuracy of the information uploaded from celect ecms.
    Donniemnemonic
  10. #654
    Junior Member sara_suansun's Avatar
    Default Need help
    I need rom boot mode schematic for QSK19 ecm part No 3867743
    Please any body help me
    Best Regards
  11. #655
    Top Poster Thecell's Avatar
    Sep 2011
    Florida USA / London UK
    Hi Hpcummins
    Donniemnemonic
    Pm me with the specific model...I will look to see what I have.
    BP
  12. #656
    Oct 2010
    Hi Hpcummins
    Donniemnemonic
    Here is a celect e2m that I believe is a different number than JC Tech's. It's the only one I have. Let me know how it works.
    HP
  13. #657
    Top Poster bekamon's Avatar
    Mar 2009
    Default ECM REPROGRAM
    hello , I have a ECM of ISC/ISL whit the following problem , INITIAL FOOTPRINTED, how i can do to reprogram it
    plesas help me
  14. #658
    DK Veteran jctech's Avatar
    just beyond the edge of reason
    Quote Originally Posted by bekamon View Post
    plesas help me
    Use Insite and the InCal disks (posted elsewhere). Be sure to use the "save and restore" option in Insite
  15. #659
    Default Some one help me plaease
    I need rom boot mode schematic for QSK19 ecm part No :3867743
    Please some one help me
    Best Regards
  16. #660
    Nov 2010
    Here is a celect e2m that I believe is a different number than JC Tech's. It's the only one I have. Let me know how it works. HP
    Hi m8sThanks for the e2m file you posted Hpcummins. Have tested it and still reading the wrong part and serial numbers. Tested with P/N 3618046, 3619037 and 3084473.Does anyone have an e2m file for these part numbers that works correctly? Please post if any.The Cell please post the celect e2m files you have.RegardsDonniemnemonic
