Page 51 of 56 FirstFirst ... 414647484950515253545556 LastLast
Results 751 to 765 of 826
  1. #751
    Dec 2010
    PLEASE . help me ecm cummins N14 . faul code 352 . ZkTcyxl.jpg . revised harness and the correct voltage 5v, correct ground return. which can be within the ecu?
  2. #752
    Russia
    May be some pressure sensor do it short to ground
  3. #753
    Roy Suryadwiananda's Avatar
    Indonesia
    Quote Originally Posted by hugos31 View Post
    Please try to replace the Sensor Intake Manifold Pressure, locate back of the Intake manifold.
  4. #754
    May 2016
    Das any one have Cummins Insite PC ID 8858F5D6 Verification Code 1C4D7-847D2 Build vertion 7.6.2.240 SPS Password ?
  5. #755
    Indonesia
    Quote Originally Posted by Giran View Post
    Try this > H0Z-1X8-7OP-6JA-SI9-56G
  6. #756
    Dear friend,I have two ECUs CM570.They were on ISX engines and I recalibrated the both for ISM engines.The both have DTC 323,fault for 5th injectors,but in insite on cut out test all inejctors work,but fault is active.ECUs did not have problems and faults on ISX engines.Communication lines work fine.Please help.Thanks in advance.
  7. #757
    Russia
    ISX don`t have connection on the 03-04 pins(inj5 on the ISM). ISX 03 pin- priming pump return no diagnostic code. May be internal defect ECM control injector 5.
  8. #758
    Member jhon silva's Avatar
    Sep 2012
    Colombia
    Hello friends, I have ECM Cummins ISX P/N 3408501, Water entered the ECM and the engine will not start and communication with INSITE is flawed, to revise find myself alone on the big green 12v capacitors, I know it must have 130v in these capacitors, any suggestions please .... I have 3 days reviewing but can not find the fault ..IMG_20160601_153017.jpgIMG_20160601_152954.jpg
  9. #759
    Indonesia
    Quote Originally Posted by jhon silva View Post
    ROM boot again.
  10. #760
    Dec 2010
    el salvador
    Hi.need help i have celet Plus ecm for n14 this have fault code 111.how program the memory to solve the problem
  11. #761
    DK Veteran mathura's Avatar
    Aug 2011
    Quote Originally Posted by ortiz View Post
    code 111 is a hardware failure, most times you cannot get it to work again unless you understand how to repair ecm.
  12. The Following User Says Thank You to mathura For This Useful Post:
    colh (23rd July, 2016)
  13. #762
    Jan 2016
    Mexico
    Hello, I have a cummins CM570 ECM just as the one Jhon Silva had, the same problem, water inside. and truck doesnt start anymore. Cant get high voltage on green capacitor, and cannot communicate with insite. no visual damage to components, Any ideas on how to repair? thanks!
  14. #763
    Aug 2016
    Hi, anyone have schematic for n14 celect plus ECM
  15. #764
    Aug 2016
    canada
    ive seen engine brake wire harness short out before the jake and cause issues with ambient air and crank sensor which takes out capacitator inside ecm. also a bad batery connection will cause issues too.
  16. #765
    Aug 2016
    canada
    replace ecm cheaper than going thru ecm
